REALTEK HD AUDIO MOD For Clevo
Discussion in 'Sager and Clevo' started by j95, Mar 23, 2018.
  1. j95
    j95 Notebook Deity
    No problem. My next Realtek driver package will include Audio Console 1.2.136.0.
    ZamirKM likes this.
  2. j95
    j95 Notebook Deity
  3. ZamirKM
    ZamirKM Notebook Enthusiast
    Hello! If I have Realtek Audio Console installed? Want to uninstall Realtek Audio Console before installing Realtek_UAD_6.0.1.8522_Clevo_mod and reinstall Realtek Audio Console? Thank you!
    j95 likes this.
  4. j95
    j95 Notebook Deity
    Uninstall Realtek UAD drivers under "Programs & Features" (Control Panel) and Realtek Audio Console/UWP under "Apps & Features" (Settings).
    Run Autoruns64.exe as admin. Filter: Creative. Only delete "UWP.service" entry as shown below (right click/delete).
    Once again, disable driver signing before installing drivers (...Clevo_mod.exe)
    ZamirKM likes this.
  5. epguy3
    epguy3 Notebook Evangelist
    wow, I did not know the updated Creative component DLL file also had problems in the newer Realtek UAD drivers.
    here are the required Creative MBAPO2 DLL extension file versions for SBX360/720 in Realtek HDA legacy driver (for Win7/8.1 use up to 1.2.65.18 - for Win10 use 2.0.0.3)
    Win7/8.1 users should just use 8308 or 8328 HDA driver while Win10 users should use 8454 HDA driver
    j95 likes this.
  6. ZamirKM
    Thank you dear man! Installed UAD 8522, it works, everything is fine! How to thank you? 8522 UAD.jpg
    j95 likes this.
  7. j95
    j95 Notebook Deity
    It's even worse than you think.
    8522 HDA MBAPO264.dll 1.2.16.131 (Creative signing time Wednesday, ‎January ‎4, ‎2017 11:10:33 PM) and mbfilt64.sys 6.10.0.14...a real mess.
    You need to find out which is the best driver version for your specific laptop model.
    ZamirKM and Papusan like this.
  8. ZamirKM
    Greetings! How to find out? p670rs-g model of the laptop. Thank you for your reply.
  9. ZamirKM
    @j95
    Hello friend, I'm sorry for your concern. I have a laptop Clevo, on the laptop there is a sabuffer, but it does not work, how to turn it on? Thank you for understanding.
    j95 likes this.
  10. Lightning_-
    Lightning_- Notebook Consultant
    It probably works, its just that it's kinda weak to notice. Try this sub test and feel if your subwoofer vibrates during the test:
    j95 likes this.
