REALTEK HD AUDIO MOD For Clevo
Discussion in 'Sager and Clevo' started by j95, Mar 23, 2018.
  1. j95
    j95 Notebook Deity
    P870DM-G (1903 Build 18362.239
    Clevo Mod Installation:
    Run DDU (latest version) to uninstall previous version. Select “Audio” -> Realtek -> uninstall without rebooting, and then set “Creative” option, finally reboot.
    You must disable both driver signing and any anti-virus software before installing driver mods.
    Copy Realtek…exe to the desktop and then right click “run as administrator”
    When prompted (4x) select “Install driver software anyway”
    Exit realtek Installer without rebooting to complete RTK Audio console and SBC installation.
    After rebooting, disable and re-enable “Jack detection when device is plugged in” (Realtek Audio Console advanced settings).
    Disable Power management
    andrewff2, Ashtrix, KY_BULLET and 5 others like this.
  2. Danishblunt
    Danishblunt Guest
    I'll be testing this.
    I'll record the differences with my podcast mic instead of my phone mic to give people the best idea.
  3. jaybee83
    jaybee83 Biotech-Doc
    ive seen your audio mods before, but....what exactly is modded in there? :D forgive me for being a noob in this regard ;)
    j95 likes this.
  4. blacklord049
    blacklord049 Notebook Enthusiast
    Will it work on a W650KK/KJ1 ?
    I tried installing the latest driver provided on the official download page but audio output was not working even if the driver was correctly installed and recognized
    What's the point of this mod?
  5. Danishblunt
    Danishblunt Guest
    I hope the point is to improve audio quality, I'm about to work on it, review with podcast mic recordings will be up today I think.
    Also it should be, yes.
  6. Danishblunt
    Danishblunt Guest
    Danishblunt review of the mod:
    So I downloaded the mod and installed everything according to the guide. I could notice that I got a new funny dolby tab open and saw that the driver date was as on the picture in the OP. I turned my notebook on and noticed that the sound was really weird. Very unbalanced and there seems to be a slight emphasis on the subwoofer. I proceeded to download the Equalizer APO and set everything up as good as I could. The sound was improved by quite a bit. I only spend around 30-40minutes on fiddling with APO so I think people can get better results in the end. So how was it?
    Stock vs Modded
    How was the testing was performed:
    I took a youtube video with a cover song from one of my favorite animes of all time and recorded it due to copyright issues. I took a podcast microphone and put it on all 3 tests exacly 30cm on the exact same position on the table with the notebook to ensure you also get the idea of the volume. I set all volumes to 100% and started recording, the reason for this was because all 3 tests had a different max volume.
    Here is the result:
    Observation:
    The stock driver was louder than the modded + APO, but the speakers were less tinny and much less ear damaging. I swear P375SM-A speakers on max volume actually give you a headache. The mod gives a more full tone, although still not really perfect. Also I noticed that the sound was a little bit unbalanced, maybe i messed up a bit on the settings in APO, but the bass on the subwoofer was a bit to much compared to the normal singing, it "popped" a bit to much to my taste compared to the rest of the sound. The mod + EQ is still no masterpiece and still far from perfection (hence i included a version from my custom drivers) but in the right step. Maybe someone can build more on this.
    Conclusion:
    The customizability of the mod allows users to fix some issues, despite not being perfect imo it beats stock drivers + SB by quite a bit and people should give it a shot.
    @slimmolG
    You might want to try this mod!
    @aIex
    So the EQ was better than expected! You were right, it did actually do better than I thought.
    Dr. AMK and j95 like this.
  7. aIex
    aIex Notebook Consultant
    I feel like it hasn't improved sound quality that much over stock + my Equalizer APO settings, but has crippled the sound when listening on headphones.
  8. Danishblunt
    Danishblunt Guest
    My video basicially showcased that as well. It's still an improvement, however the headphone part is important.
  9. j95
    j95 Notebook Deity
    Unlocked DHT, DDL & DTS.
    Signed RltkAPO64.dll.
    Silent Installer.
    Please post HWIDs, OP "supported models".
    Sounds like you've enabled DHT, try unchecking DHT. It works pretty well w/ P870DM2/3, unlike my P870DM.
    Please post HWIDs
    Stock and modded driver versions?
    Dr. AMK and jaybee83 like this.
  10. blacklord049
    Hi,
    HDAUDIO\FUNC_01&VEN_10EC&DEV_0269&SUBSYS_1558651A&REV_1002
    Audio Codec ALC269
    Drivers 6.0.1.8295 (downloaded here http://www.clevo.com/en/e-services/download/ftpOut.asp?Lmodel=W65xKK1/W65xKJ1&ltype=9&submit=+GO+) don't give any audio output. Device doesn't report any error in device manager and sound control is present in the taskbar but Windows is not able to produce any sound. Tried most recent generic drivers (through station-drivers) and they don't work either. I've uninstalled Sound Blaster Cinema 3, maybe it causes some kind of conflict.
    I don't see my HWID in your list though.
