RealTek HD audio does not start
Discussion in 'MSI' started by etcetera, May 30, 2019.
  1. etcetera
    etcetera Notebook Evangelist
    I need to adjust the settings in RealTek HD audio application. I have the very common problem of microphone sound being very low.
    I tried all revisions that are commonly suggested to no avail, the program is visible in device manager but not in start menu or anywhere else and it's impossible to start it.
    what version of driver works and enables RealTek HD audio app to start in latest Win 10 on Titan GT80 SLI?
  2. hacktrix2006
    If your talking about the Realtek Audio UWP app, simple head to task manager to the start up tab and look for Realtek item it might be set to disabled, if it is enable it and reboot the system it will then work after that.
    Sent from my LLD-L31 using Tapatalk
  3. hacktrix2006
    If you downloaded the Lastest Version from my signature there was a filename bug in it. So redownload and all should work well again.
