Re-applying thermal paste
Discussion in 'Sager and Clevo' started by kevindd992002, Jun 29, 2009.
  1. kevindd992002
    kevindd992002 Notebook Virtuoso
    In re-applying thermal paste to my M860TU CPU and GPU, can I get away by re-using those thermal pads that came with the GPU? Or do I need to replace them?
  2. Oiad
    Oiad Notebook Evangelist
    You'll get told that you should replace them. I should have replaced mine. Didn't of course and reapplicating the paste it runs cooler than ever. :p
  3. Static Space
    Static Space Notebook Guru
    So far I've reapplied the paste 3 times (including upgrade to GTX 260M) and I had to reuse those gap thermal pads on the memory chips. Mind you, they don't look like good quality ones.
    Yet I wasn't able to find for sale good 1mm gap pads like Bergquist and such. If someone has an idea, let us know please.
  4. kevindd992002
    Ahh.. So the "recommended" is to replace them?
    This may seem silly, but can you apply thermal paste in the RAM chips? Lol
  5. Static Space
    No, because memory chips do not touch directly the heatsink, there's a small gap between them, hence the gap thermopads. Which I can't find in small quantity anywhere. :mad:
  6. kevindd992002
    Ahh.. So it's safe to re-use them?
    Also, with my M860TU, most people say that the NorthBridge is the culprit for the hot right palmrest for most users.
    I took the liberty to unscrew the northBridge heatsink and saw that it uses thermal pads where in fact you can use thermal paste with it, I think.
    But the problem is that it contains a black film in between the thermal pad and the heat sink itself so I don't know if applying a thermal paste is recommended with that staff.
    Anybody can confirm this?
  7. Static Space
    I also wanted to apply thermo paste to the Bridge but you see that thermo pad, if u remove it and apply thermo paste your heatsink will not have the contact with the bridge.
    Also the heat on the right palm rest is due to wi-fi card, not the northBridge.
  8. kevindd992002
    Ohh really? Because there is space right?
  9. Static Space
    Affirmative.
  10. kevindd992002
    Dammit, so where stuck with this?
    Is your right palm rest also hot?
