RB17PRO 2020
Discussion in 'Razer' started by Darkhan, May 26, 2020.
  1. saturnotaku
    Sadly, no.
  2. Silentfan
    Silentfan Notebook Geek
    Hi,
    has the 2020 model new fans? Or they have still so high frequency noise? I mean the big main fans.
  3. CitizenPanda
    CitizenPanda Notebook Deity NBR Reviewer
    Same fans as far I know. The higher frequency are the small fans I think. They aren't too bad.
  4. CitizenPanda
    I just discovered that my 2020 pro 17 4k120 allows me to turn on G-Sync in Nvidia system panel. Can someone check to see if to works? I don't have any FPS I can test right away.
  5. saturnotaku
    Download and install the NVIDIA Pendulum demo as it specifically tests G-Sync compatibility.
    alaskajoel and Darkhan like this.
  6. Silentfan
    I think so, too (same fans).
    No, the big fans has also a high frequency, I have testet it.
    alaskajoel likes this.
  7. pitha1337
    pitha1337 Notebook Consultant
    Could you verify G-Sync?
  8. Joikansai
    Joikansai Notebook Deity
  9. Shark00n
    Shark00n Notebook Deity
    Im on BIOS 1.03 in a Blade Pro 2019, everything is working fine, is it a good idea to update to the latest version?
    Also, what's the best option to do a repaste with? Kryonaut?
    Ty
  10. saturnotaku
    If it's anything like the 2020 models, the latest BIOS will lock out the ability to undervolt via ThrottleStop.
