RB Late 2019 Advanced Issues With Brightness Auto Sensor
Discussion in 'Razer' started by LVNeptune, Feb 14, 2020.
  1. LVNeptune
    LVNeptune Notebook Virtuoso
    Fresh install of Windows 10 1909 which I suspect may actually be the problem but the options for disabling the light sensor for auto brightness are not anywhere to be found. It's super annoying when opening a page that has mostly white because the screen slowly ramps up brighter and brighter.
    Any ideas on disabling it?
    hmscott likes this.
  2. hmscott
    This keeps happening on and off since 1803 as far as I can see via search. Here's how to add / remove the auto brightness settings to / from the current power plan, and other methods:
    Add or Remove 'Enable adaptive brightness' from Power Options in Windows
    https://www.tenforums.com/tutorials...daptive-brightness-power-options-windows.html
    See the "Related Tutorials" below for more fun feature tutorials that may be of interest, like:
    I recall a time when I added a whole bunch of these to a power plan to see which worked on a laptop, some did, some didn't.
    Have fun :)
  3. rinneh
    rinneh Notebook Prophet
    It doesnt hae an auto brightness sensor but intel has power saving options which do a similar thing. GO to the Intel GPU control panel and set everything to max performance.
    hmscott likes this.
  4. Joikansai
    Joikansai Notebook Deity
    Go to Intel graphics command center->system->power tab, there’s adaptive brightness on off options (mine on default off both on stealth late 2019 and Blade 15 2018 I think).
    hmscott likes this.
  5. LVNeptune
    Everything is already max performance.
    This isn't dimming bright images. This is making it brighter which is the opposite of power saving features lol.
  6. rinneh
    What you describe sounds like the usual intel iGPU "dynamic" contrast thing.
