RB 2019 Advanced RTX 2070 Lagging with 1000hz mouse polling
Discussion in 'Razer' started by LVNeptune, Feb 8, 2020.
  1. LVNeptune
    LVNeptune Notebook Virtuoso
    CPU not spiking but randomly entire PC will stutter while playing games if I am moving my Logitech G600 mouse really fast. It doesn't seem to happen at 500hz. Can't find a solution as to why this is happening. Nothing else plugged into USB except the mouse. Any ideas?
    EDIT: Just confirmed it happens with 500hz polling as well but not nearly as bad.
  2. amihail91
    amihail91 Notebook Consultant
    I just noticed this now you point it out - my CPU-Z and GPU-Z windows lag across the screen when I drag them side to side. I'm on a RB17 Pro 2019. :/
    Anybody any ideas?
    EDIT: happens on 500hz but not 125hz but that defeats the point in using a high refresh rate mouse for gaming ...
  3. nyichiban
    nyichiban Notebook Geek
    Have not noticed this on my RB 15 2019 with G903 mouse at 1000. Drivers maybe?
  4. amihail91
    Mouse drivers? o_O
  5. nyichiban
    I had the last gen logitech gaming drivers installed not the ghub one but the ones before that. LGS 9.02.65 x64 to be exact.
  6. amihail91
    I'm using a Deathadder Elite haha, you would think their own mouse was compatible with their laptop? I'm suspecting some sort of Windows level problem.
  7. nyichiban
    did you turn off the mouse assist thing in windows? upload_2020-2-13_16-43-30.png
  8. rinneh
    rinneh Notebook Prophet
    do you use an external screen? because you mention the gpu-z and cpu-z screens also stutter when you move them.
  9. LVNeptune
    I never said anything about GPU-Z and CPU-Z that was another commenter.
  10. amihail91
    No external monitor no, but those 2 particular apps lag across the screen when I drag them.
