RB 2016 review out on laptopmag
Discussion in 'Razer' started by Eason, May 6, 2016.
  1. Eason
    Eason Notebook Virtuoso
    It isn't the best review, but it does have some important information there. Battery life seems ok; better than 2015 at 5:42. However, it seems to have the exact same keyboard as the stealth.
  2. Bursotto
    Bursotto Notebook Enthusiast
    I'm wondering if that 1.1mm key travel the reviewer cited is accurate... seems like a real step backwards if so.
  3. Eason
    Yeah I think you're right. Laptopmag has done some pretty shoddy reviews and this is one of them
  4. gametime10
    gametime10 Notebook Consultant
    I don't see anything spectacular over the 2015 version at this point. You can get a used 2015 these days for under 1500 so it would be hard to justify the price difference.
  5. tusctodd
    tusctodd Notebook Enthusiast
    Unless you want to use the core.
    The core with the new GTX 1080 sounds like an interesting combination
  6. Bursotto
    Some comments on the review have called it out for being a sponsored review and I believe it.
    Eason likes this.
  7. Eason
    As I was saying- I think she's a bad reviewer in general and they always read full of product placements. I'm not sure if she always does sponsored reviews, or just the poor quality/deptch looks like sponsorship.
  8. rinneh
    rinneh Notebook Prophet
    Laptopmag is more for the technical not so inclined people I suspect. Not a lot of technical data. Just an overall feeling of a product. Not very critical in general.
    NBC is one of the biggest review sites out there and fairly technical. But After trying multiple GIgabyte laptops they reviewed as good choices and well built while not being that for me with daily usage made me doubt even them.
  9. Eason
    Did you see NBC's pink macbook review? All that data and tests and then WHAT THE **** 91%?!?! Using which parallel universe's math were they calculating that average?
  10. Bursotto
    Lol the 2016 Blade Delayed thread on Razer Insider forums is such a circus.
