Razor Blade Stealth - 12.5", i7-6500U, $999
Discussion in 'Razer' started by aethelbert, Jan 5, 2016.
  1. Eason
    Eason Notebook Virtuoso
    Shipping from the 23rd, so they claim.
    hmscott likes this.
  2. eth3rton
    eth3rton Notebook Consultant
    What has the battery life on the RB Stealth been like? 6 hours too much of a reach?
    Thanks!
  3. Eason
    6 hours with battery saving mode on, keyboard on dim, and using edge, yes.
    hmscott likes this.
  4. pokey2014
    pokey2014 Notebook Geek
    My qhd stealth with 256ssd keeps booting to bios , pressed f12 and nothing shows up in the boot menu.
    Sent from my SM-G935F using Tapatalk
  5. Makyura
    Makyura Notebook Consultant
    Your ssd is probably dead, happened to me on a zenbook too.
  6. jedisurfer1
    jedisurfer1 Notebook Deity
    is the ram upgradeable on these or are they all soldered. 8gb on some of them is simply not enough
  7. kent1146
    kent1146 Notebook Prophet
    Soldered on. Not upgradeable.
    And yes 8GB is low. But it's not unusable. 8GB is actually enough for most of what people do on a computer. If you run a single game, or use multiple 10's on tabs on a web browser, you're not going to even use all 8GB, let alone come close to needing 16GB.
    8GB of RAM only becomes an issue when you do either do unnecessarily heavy multitasking (e.g. keep 50 Chrome tabs open, while also running a game), or start running programs that don't belong on a low-power dual core mobile CPU (e.g. virtual machines, large databases, RAM disks).
    So if you aren't a power user, or if this isn't your primary computer where you will be running power-user jobs, then you can probably get by with 8GB of RAM. But if you really think 8GB will become a problem, then I'd consider a Dell XPS 14, Dell XPS 15, or Razer Blade 14.
    Sent from my SM-G935V using Tapatalk
