Razor Blade Stealth - 12.5", i7-6500U, $999
Discussion in 'Razer' started by aethelbert, Jan 5, 2016.
  1. aethelbert
    aethelbert Notebook Evangelist
    All signs seem to indicate Razer will launch a new device at CES soon. This will feature an i7-6500U and Intel HD graphics. Supposedly it will feature a 1440p display and external graphics as well.
    What do you guys think?
    Full specs:
    • 12.5-inch QuadHD (2,560 x 1,440) resolution touchscreen
    • Chroma-lit keyboard
    • A model with a 4K touchscreen is also available.
    • 0.52-inches thick
    • 2.75 pounds
    • Two USB 3.0 ports
    • USB-C Thunderbolt 3 port.
    • Intel Core i7-6500U dual-core processor
    • 8GB of RAM
    • 128GB/256GB (QuadHD display model)
    • 256GB/512GB (Ultra HD display model)
  2. Nivaku
    Nivaku Notebook Evangelist
    I like the idea, but the bezels are a really big turn off. Should be thin bezels similar to the Dell XPS 13. Probably similar with screen size also, is it possible that IGZO panels come with that size only?
    I really hope they refresh their Razer Blade 14 line, as I'm more interested in that
  3. pau1ow
    pau1ow Notebook Deity
    I definitely like the concept, but the 6500U will definitely be a bottleneck in hi-fps games :(
  4. aethelbert
    The same reason the Alienware 13 interested me until I saw it had a ULV CPU. Hopefully this can find its way onto the Blade 14.
  5. Makyura
    Makyura Notebook Consultant
    Looks decent, but I still believe that if you want desktop performances you will need a desktop PC, even a "small" one, or a bulky notebook like MSI GT82 or similar devices, so I wouldn't really buy this considering the external desktop GPU an option; 6500U and 8GB of RAM look "bottlenecky" for intensive work tasks and gaming (altho 8gb of RAM might be enough for it).
    The whole ultrapowerful ultrabook idea is cool tho, and the 999$ version is kinda cheap considering what's inside of it.
    Regarding gaming, Razer Blade 14" is still my n. 1 option from this brand.
  6. Templesa
    Templesa Notebook Deity
    This absolutely bare minimum should've had Iris 540 (the one with 64mb of dedicated L4 cache and double the shaders) in it. I would've bought it today if it did. I'm still interested, but it's going to cost me the same as regular Blade by the time I really get done with configuration of an expensive port + GPU. And I'd still have to make do with a dual core...
    Now imagine the Razer not throttling that i7... Huge missed opportunity.
  7. Eason
    Eason Notebook Virtuoso
    I know it doesn't make sense, but I kinda want to trade my 2015 QHD+ Razer Blade for a Stealth ._.
  8. IKAS V
    IKAS V Notebook Prophet
    Really like the concept but like others wish it had better CPU, does anyone have any hard numbers of just how limiting that is?
    It would be awesome if the dock was compatible with other thunderbolt supported laptops and not only the stealth, it would be worth buying as a stand alone unit itself if that were the case.
  9. PyroDonkey
    PyroDonkey Notebook Consultant
    Here's a good video
    showing how cpu bottlenecks can affect performance when using a Titan X. The Blade Stealth's CPU won't perform as high as the 6100, but it's an interesting video, nonetheless.
  10. IKAS V
    Thanks for the video.
    Not sure how much that applies to this laptop since those are all using desktop CPU's.
    Maybe a AW13 owner that has a amplifier can answer better but just trying to figure out all the benefits of what a low voltage dual core CPU and desktop GPU brings to the table.
    I think a TITAN X might be a bit too much GPU, any ideas what might be a decent match for this particular CPU?
