Razer forum is a disorganized mess...
Discussion in 'Site Suggestions, Announcements and Guidelines' started by reloader-1, Oct 12, 2016.
  1. reloader-1
    reloader-1 Notebook Geek
    Can someone go into the Razer forum and clean up the stickies? Right now it's a disorganized jumble and is limiting posting (and thus revenue for NR).
    Razer has two existing laptops currently on the market:
    1. Razer Blade Stealth (late 2016)
    2. Razer Blade 14" (late 2016)
    Razer's naming system is similar to Apple's, in that all their laptops have the same name as previous generations (I.e. MacBook Air). This is leading to a ton of confusion as currently stickied threads refer to products from 2011! It would be better to put up a new sticky for the latest generations and unstick the older threads as they are irrelevant.
    Basically, here are the three thread titles that should be stickied:
    1. Razer Blade Stealth (late 2016) Owner's Lounge
    2. Razer Blade 14" (late 2016) Owner's Lounge
    3. Razer Edge & Edge Pro Owner's Lounge
    The last is a legacy product that has been discontinued but still has a fair amount of activity, and is already a current sticky.
    Thanks!
  2. Charles P. Jefferies
    I unstuck the existing threads for now, I'll take a look later today to see if we can organize it another way. Otherwise I'll take you up on your suggestion to stick those threads.
    Thanks for checking in.
    Charles
  3. reloader-1
    Thanks Charles.
    As Razer refreshes models or adds new ones I'll definitely check in with you in order to keep the latest products on top.
  4. Charles P. Jefferies
    Cool. I made the threads you suggested a sticky.
    Charles
    ALLurGroceries likes this.
  5. reloader-1
  6. Charles P. Jefferies
    I took care of that.
    Charles
