Razer DeathAdder double-click issue
Discussion in 'Accessories' started by Kain, Oct 15, 2009.
  1. Kain
    Kain Notebook Evangelist
    Sometimes when I single-click with the left mouse button, the DeathAdder performs a double-click. It's really annoying when it happens. What should I do?
    By the way, I performed a Google search regarding this and it seems quite a few people have this problem with this mouse.
  2. Mastershroom
    Mastershroom wat
    Hmm, that's never happened with mine, and it's over a year old. Perhaps contact Razer support and see if they'll replace it?
  3. Buckits
    Buckits Notebook Consultant
    Many mice do that... my logitech v220 started doing it a few weeks ago and logitech actually has an FAQ for it. To remedy the situation go to MyComputer > click on the Organize Tab (upper left) > click Folder and Search Options > and under Click Items As Follows select Single Click. It reduces the number of times a double click will happen, but I have notice once in a while it might squeeze in another. I thought for a while I messed up the clicker cause I gamed heavily on it (im one of those players that clicks pretty hard). So let me know if it helps you out.
  4. DarthWayne
    DarthWayne Notebook Consultant
  5. Narthecium
    Narthecium Notebook Evangelist
    Good luck with that. Unless you bought the mouse from one of their list of authorized retailers (and not from ebay, etc) they'll refuse to honor any warranty or do any repairs on it.
  6. crayonyes
    crayonyes Custom Title! WooHoooo !!
    Easily solved by replacing the microswitch. (if cleaning it didn't work)
    Heavily abused mice or mice with bad microswitch often have this because of wear-and tear
  7. Mastershroom
    Mastershroom wat
    I bought it directly from Razer's own site.
  8. sentinellY
    sentinellY Newbie
    I myself have the same "duo click" problem recently, since i update to the latest DA driver & firmware. When i try single click, it just double it up; also when i hold & drag it just releases... very annoying... I then use an uninstall program to delete the driver & firmware completely, then my mice come back to normal ! Interesting.
    My oppinion is that the real problem is in the firmware....
  9. GtsXracer
    GtsXracer Notebook Consultant
    I would email Razer and get an rma to send it in if it is still under warranty
  10. evilnine
    evilnine Newbie
    There's a firmware update that fixes this issue on the razer site, it worked for me.
