Razer Core Disassembly & Fan Location Guide
Discussion in 'Razer' started by Lauski, Feb 27, 2017.
  1. Assembler
    Assembler Notebook Consultant
    How did you made those adapters if I may ask ? I am in the process of replacing the fans, but this is the only step where I am stuck. I do not have any tools or experience in such things, but I am able to get all the cables / connectors and some neat fitting fans.
  2. Lauski
    Lauski Notebook Consultant
    The one side is the JST 1.0mm 4pin connector. You can search for these online. I found some on Amazon without too much trouble in the U.S. Next, the other side is just a standard female PWM fan connector. Make sure if you're changing the fans you put in a fan that is PWM. Standard 3-wire fans are going to just run at full speed, I found from my testing.
