Razer Blade Pro Late 2016 - fans not working
Discussion in 'Razer' started by TheMadMan, Jul 5, 2018.
  1. TheMadMan
    TheMadMan Notebook Geek
    Hi,
    I was playing a game earlier and noticed a lot of stuttering. I then realized the fans weren't spinning up so I'm guessing that there's some throttling going on due to over heating.
    Does anybody know of a way to test the fans to see if they have stopped working? If they have stopped working, any ideas on what I could do to try and get them working again?
    Thanks.
  2. ngvuanh
    ngvuanh Notebook Deity
    Fans might not stop working but you could have lint and dirt block the air flow. However, if you don't hear any noise from fans, then they are probably dead.
    You can open bottom cover using T5 Torx screw driver and check for dirt or fan problem
    TheMadMan likes this.
  3. TheMadMan
    Thanks for the reply. I'll see if I can open the back and check. If they're dead I'm guessing it's a RMA?
  4. Joikansai
    Joikansai Notebook Deity
    You can check the grill I think it’s visible and noticeable when the fans don’t spin. Since it’s already over a year maybe you have to do dusting on it even it works but you get thermal and stuttering issues.
    If it still under guarantee, I’ll send it though rather than opening by my self, let them the professional do their job.
  5. TheMadMan
    Got a replacement. Thank god I ordered from Amazon!!
