Razer Blade Pro Early 2017 CPU & GPU Tweaks (Some tweaks apply for Late 2016 model)
Discussion in 'Razer' started by Hackintoshihope, Aug 1, 2017.
  1. Nuke33
    Nuke33 Notebook Consultant
    Okay you are right it is preference.
    I have undervolted and overclocked quite a few desktop cpus, and by doing so I learnt that having full control over as many settings as possible is a must for good results.
    For beginners XTU will absolutely suffice though.
    As for the Cache, as I said it is in fact Ringbus. And undervolting Ringbus by a high margin is not good for overall system stability. It might not result in outright bluescreens, but can also cause sluggishness and other unwanted effects in certain load situations.
    But lets leave it at that.
    I did not want to highjack your thread. ;)
    Hackintoshihope likes this.
  2. Hackintoshihope
    Not at all a hijack very informative and helpful to anyone wanting to do some modifications to their systems.
    Nuke33 likes this.
  3. Mobius 1
    Mobius 1 nͫٴiͤٴcͫٴeͤ੮Һ૯ ცɿ૭ ૭คעٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴ⎬⎛⎝⎠⎞⎨
    meme/10
    @D2 Ultima @bloodhawk
    Papusan likes this.
  4. Vasudev
    Why not uninstall XTU and install ThrottleStop, surely RZ Synapse won't disable it. If it disables TS, then disable or put Razer Synapse service to manual.
    Papusan likes this.
  5. Nuke33
    I am glad you like it.
    But nonetheless I will open a new thread in the near future to discuss such matters. ;)
    Isn´t this going to disable all Chroma functionality too ?
    Vasudev likes this.
  6. Hackintoshihope
    It doesn’t “disable” it. It scans every 3-5min and rests overlock settings. To the razer defined defaults so you must set the RzPerformance service to disabled so it won’t run, not the entire Razer Synapse.
    This is why you simply disable the service I mentioned.
    Vasudev and Nuke33 like this.
  7. Mobius 1
    Why on earth they would do that just baffles me
    Papusan and Vasudev like this.
  8. Hackintoshihope
    Razer is the new apple xD.
    Papusan, Vasudev and Nuke33 like this.
  9. Nuke33
    To ensure "Best possible User Experience" :D
    Vasudev and Hackintoshihope like this.
  10. Vasudev
    Maybe Apple -2.0 w/ lights.
    Vistar Shook likes this.
