Razer Blade Pro 17" GTX 1080 GPU/7820K CPU 2017 Owner's Lounge
Discussion in 'Razer' started by shoespc, Apr 13, 2017.
  1. Joikansai
    Joikansai Notebook Deity
    Double post
  2. Joikansai
    It’s great temperature for Blade Pro. If you’re not familiar with bios moding I’d stay with current setting, there’s a risk even personally low, but it may brick your system if you messed with the setting. Razer bios is quite tight even you can unlock some function it may not be apply able on real usage, I tried to adjust fans curve per bios yesterday and didn’t manage it, it didn’t apply but it still kicking on on default temperature.
  3. Elphie
    Elphie Notebook Enthusiast
    Well yeah I haven't done it before and if the risk was great I would be glad to follow on your advise as I don't want another headache :/
    I was skeptical at first on reopening my laptop during the full blast fiasco since my temp on full load both CPU and GPU it never went past 76C on both however I know my fans will burn out soon so i decided to reopen it again just a shame, the RBP could even be cooler with couple more tweaks in fan when plugin or during heavy load at users will, but Razer decided to lock it down.
    And by the way speaking of tweak when I use XTU it seems nothing happen, as in my temps are the same, I tried disabling RZperformance to make sure it won't conflict on XTU as I read in earlier post about it.Any thought on this one? Thank you for all your help wish I see this post a year earlier.
  4. paramount7force
    paramount7force Newbie
    Hi, ive got a razer blade pro 2017 uhd gtx 1080 i recently had it repaired by razer after the battery bloated. Problem im having is when gaming the battery starts discharging about 1% every 3 minutes. Ive read this whole thread and have undervolted the cpu using xtu but im a bit confused about using after burner. When i press ctrl f the graph shows up but its all greyed out i can move the dots around and ive seen a picture of the graph that i can copy in this thread but the lines and the dots are all greyed out. How do i undervolt with afterburner is basically my question and will that stop the battery discharging while gaming?
  5. paramount7force
    The battery is still going down by approximately 1% every four minutes while gaming plugged in. Ive sort of sorted this problem pretty much and got the battery drain down to 0.2% every 10 minutes. To do this you will need to download MSI Afterburner and the XTU Tuning utility follow all the instructions in this link:http://forum.notebookreview.com/thr...some-tweaks-apply-for-late-2016-model.807563/
    When writing this all the images had disappeared so follow this next link and make your afterburner settings the same as in the first post: http://forum.notebookreview.com/thr...u-7820k-cpu-2017-owners-lounge.803629/page-41
    Dont worry if your afterburner lines and dots are greyed out its fine just change the dots around and hit close then click on the button to start it with windows. Be Sure to disable the rzperformance service as it says in the first link(just type in how to disable services in windows 10 into google) also type device manager into the windows search bar go to device manager control panel-click on "Human Interface Devices then click on HID-compliant touch screen then right click on it and disable it(this will obviously disable the touchscreen). After that connect your razer blade pro to a 4k screen. go to project(bottom right corner in windows 10) and click on second screen only also turn your chroma keyboard lighting off and the logo lighting to off. If you go to settings in windows then system then display you can also turn on HDR streaming for games and videos. After youve done all this you should now notice that on AAA games set on ultra in 4K HDR your battery drain should fall to around 0.1-0.2% every 8-10 minutes which is enough to game all day. However when your gaming on the move, if you suffer from this problem at all that is, your battery drain is gonna be about 1% every 3-4 minutes. But with the undervolting fan speeds and temps drop greatly although my laptop screen flickers and does a little funny blank screen for a few seconds on start up but then its fine. Cheers.
    EDIT: 13/10/2019
    So with further testing you dont have to turn the keyboard lighting, logo lighting, touch screen or the screen off you just have to undervolt the cpu and then you have to undervolt the GPU properly the picture in the second link is a bit outdated so i will include a picture of my afterburner curve here. just make sure each dot is atleast a little bit above the previous dot or you will have crashing. Cheers.
    So i cant add pictures here for some reason ive added a picture at the bottom of the following razer insider thread of my afterburner curve.
    https://insider.razer.com/index.php...e-pro-2017-4k-1tb-gtx-1080.50141/#post-494177
    EDIT: 20/07/2019
    There is no doubt after further testing that undervolting the GPU and CPU gives a positive charge while gaming with everything switched on and even multiple peripherals and even a monitor plugged in. However theres a couple of things ive noticed. The battery always falls from 100% to 95%(the plugged in not charging range) if you have g-sync enabled the batery will continue to fall while gaming. So say you have g sync enabled start a game at 100% batery the battery will fall after a couple of hours to say 20% for example then when you stop the game and restart it the battery will begin to positively charge and continue to 100% then start the same cycle again. Now say you start a game with 100% charge with g-sync disabled the battery will fall to 95% then recharge to 100% then discharge to 95% then recharge to 100% etc etc. I personally prefer it with g-sync disabled as i feel it makes little to no difference having it enabled. However if anyone has any answers as to why this is happening then i am all ears anyways any comments or questions then please send a reply thanks!!!
  6. paramount7force
    This comment needs deleting.
  7. acrox999
    acrox999 Notebook Enthusiast
    Anyone else still using this laptop? Have anyone tried to switch from the 4K display to the 1080p 120Hz display? Even with a 4K display, I am running at 1080p because games work the best at 1080p and borderless windowed mode is a PITA to work with. I'm trying Borderless-Gaming but it's also a PITA.
    My battery swelled after a year. I stopped using it almost a year ago and only removed the battery very recently.
    I ordered a new battery but now it made me thinking that maybe I should've saved the money for something better. The battery alone costs 100 USD and there's no way to tell if the battery will not swell again after a year. The whole laptop as a package is really hot and the original battery says, "DO NOT EXPOSE TO TEMPERATURE ABOVE 65 DEGREES CELSIUS." I know Razer engineers are stupid but not this stupid. They made a huge laptop with two fans that are as small as a fish brain. I don't know what they were thinking while designing this.
    This laptop, it seems to me, is not designed for long gaming sessions. It forces you take breaks every a couple of hours, let the laptop cool down before turning it on again. It also seems to work best in a very cold environment. A room with very good air-conditioning will help, but even then, the CPU would run at 80 degrees Celsius. And you won't be in that kind of environment all the time.
    mason2smart and hmscott like this.
  8. Elphie
    I sold mine and given up fixing it to keep it cool. And I have to agree with you in most cases. Anyway I'm not too sure but I think that laptop feeds off a portion from battery during intense gaming where both CPU and GPU loads are high to compensate on limited power supplied by its PSU/adapter since its only rated 250 watts. So apart from decreasing GTX 1080's max wattage (instead of 180'ish watts it like 140 or 150 watts) that 250 watts was not enough to keep it under full load thus getting some power out from the battery. And judging the performance its like a GTX 1070 instead.
    If you haven't undervolt your laptop now is a good time plus RBP 2017 works best with liquid metal it will help you with temps and also if you have acces to an external monitor, it will help the adapter by turning off display and saves a couple more watts for your CPU and GPU.
    Sent from my SM-N950W using Tapatalk
    hmscott likes this.
  9. acrox999
    I never knew about that. So that's why some games still struggle to run at 1080p even with that GTX 1080?
    Undervolting was the first thing I did since I had a laptop which had heat issues as well. (Tough luck.) Undervolted the CPU to -100mV in XTU for a year, yet the the battery still get killed off. The heat issue didn't get even slightly better with undervolting. It's just how badly designed the cooling is.
    I recently just started to create the voltage/power curve through Afterburner. It's going well so far but still as hot as a toaster. My goal is to keep the package temperature at a reasonable level so that I can put the new battery in instead of wasting my 100 dollars for nothing.
    I wanted to try liquid metal but I've never applied one. How hard and safe is it? Anyone have a precautions and reviews around here regarding liquid metal performance on the RBP 2017?
  10. slimjim8201
    slimjim8201 Notebook Consultant
    My experience echoes everyone else here. I've got liquid metal in mine and I run a nice under-volt on the GPU. I've actually stopped under-volting the CPU as it has led to major stability issues. I've gone through two batteries and I will not put another in the machine, effectively making it a desktop computer. I always saw a bit of trickle power out of the battery during gaming sessions but it was never more than a few % per hour. Battery swelling is 100% caused by the heat, not the extra juice to compensate for the 250W power supply. None of these batteries should ever operate in the temperature range they are subjected to in a machine like this. Any additional heat generated in the battery from the steady, lower power draw is negligible compared to the baseline chassis heat soak.
    There was a time not long ago at all that I had sworn off all Razer machines forever but all signs point to massive cooling improvements with the latest generation machines. Particularly the RBP with the additional cooling fans. The vapor chamber appears to be massively more efficient at removing heat. I'm holding out for the 17" Studio version when it drops this fall. Curious how they will fully power the 8 core i9 processor, given the 45W power limit, but I'm confident temps will be held in check.
    hmscott likes this.
