Razer Blade Pro 17" GTX 1080 GPU/7820K CPU 2017 Owner's Lounge
Discussion in 'Razer' started by shoespc, Apr 13, 2017.
  1. slimjim8201
    slimjim8201 Notebook Consultant
    No rush! Just love talking about/reading about hardware. Part of my line of work involves using simulation tools to predict performance and optimize thermal behavior of electronics systems. Curious what you find on the inside of the RBP.
  2. slimjim8201
    Anyone care to share their GPU undervolting/over clocking success?
    I'm gathering some data on power consumption at the moment. Running Valley at various resolutions to see how this thing ticks. Looks like CPU power drops a lot at 3440x1440 vs 1080p. 5M pixels vs 2M.
    I've got my RBP hooked up to a power supply with wattage/current readouts. It appears that the resting power draw of non-CPU/GPU components is 20 watts plus about 5 for the unloaded CPU and 45 for the unloaded GPU. I'm using an external monitor so that LCD panel is one variable eliminated.
    Will post some numbers from the testing soon.
  3. Mobius 1
    Mobius 1 what is quality control?
    have you tried to lock the gpu to 0.925 or 0.9v?
    can use msi afterburner curve editor
    Vistar Shook likes this.
  4. slimjim8201
    I've read a few guides on doing that and I'll admit, I'm still a little unclear. What I know for sure is that I can bump up the clock speed 200 MHz in AB and everything runs just fine. Anything above that and I have crashing.
  5. Vistar Shook
    Vistar Shook Notebook Evangelist
    It seems like you are just overclocking the whole curve by 200 MHz....what you want to do is lock a specific MHz at a specific voltage. In AB do a ctrl+F, it will bring up the MHz vs Voltage curve...
    looks like this...
    http://imgur.com/a/fL1pR
    If you want to lock the voltage at 0.925v for example...the points after that voltage have to be flat.
    Example,
    http://imgur.com/a/P7yTA
    In this case the voltage is locked 800mv and 1740MHz
    hmscott likes this.
  6. phila_delphia
    phila_delphia Notebook Consultant
    As Vistar Shock said, you should flatten out the curve after the desired voltage. 1798mhz at 875mV is a sweetspot for me,
    YET: you should not flatten out the complete line (if you do not want to underclock) -> this will allow the card to react to very jumps in load or very high load.
    If you want you can take a look at the following link: http://forum.notebookreview.com/thr...s-owners-lounge.795090/page-290#post-10356883
    Best regards
    phila
    hmscott and Vistar Shook like this.
  7. slimjim8201
    @phila, thanks for the clarification. I think I've got it.
    Side question... how does the system determine what to shoot for? I assume that's in the vbios? Given the ~150W power limit, is it requesting the largest voltage possible?
  8. slimjim8201
    Re: chroma lighting and synapse. Is this software junk or what? I assume that it frequently loses its connection to the cloud or something when it just defaults to solid white or just FN keys lit in white. I would guess that the lighting is not functioning properly 50% of the time. I recently took Synapse "offline" to see if that has an impact.
  9. Vistar Shook
    Yeah Synapse is very buggy....try setting up new profile/new account and see if it helps.
    Sent from my SM-G930F using Tapatalk
  10. slimjim8201
    1822MHz @ 900-950mV seems to work well. Basically a 186MHz overclock with a max voltage of 950mV. Achieving consistent 16300+ in FS and it's definitely saving a few watts.
    hmscott and phila_delphia like this.
