Razer Blade Pro 17" GTX 1080 GPU/7820K CPU 2017 Owner's Lounge
Discussion in 'Razer' started by shoespc, Apr 13, 2017.
  1. shoespc
    shoespc Notebook Consultant
    New Thread for owner's of the 2017 RBP and those that wish to discuss Razer's latest system. In order to ensure our posts are beneficial to all readers please limit discussions to the Razer Blade Pro current and previous generation. If you have a positive or negative comment please ensure you provide as much detail as possible, this will make it easier for current owners to assist.
    17.3” THX Certified 4K UHD G-SYNC, 16:9 ratio, 3840 x 2160, with capacitive multi-touch
    NVIDIA® GeForce® GTX 1080 (8GB GDDR5X VRAM)
    Overclocked 7th Gen Intel Core i7-7820HK Quad-Core Processor with Hyper-Threading 2.9GHz / 3.9GHz / 4.3GHz (Base/Turbo/Overclock)
    Mobile Intel® HM175 Chipset
    32GB dual-channel memory (DDR4, 2667MHz)
    Windows® 10 (64-bit)
    Killer DoubleShot™ Pro:
    Killer™ Wireless-AC 1535 (IEEE 802.11a/b/g/n/ac + Bluetooth® 4.1)
    Killer™ E2500 (Gigabit Ethernet 10/100/1000)
    Anti-ghosting individually backlit ultra-low-profile mechanical keyboard
    Multi-point touchscreen interface
    Built-in webcam (2.0MP)
    Multimedia keys with scroll wheel
    Multi-touch touchpad
    SDXC card reader
    Thunderbolt™ 3 (USB-C™)
    USB 3.0 port x3 (SuperSpeed)
    HDMI 2.0 audio and video output
    Built-in stereo speakers
    Built-in array microphone
    THX Certified 3.5mm combo audio port
    Dolby® Digital Plus Home Theater Edition
    7.1 Codec support
    Keyboard and trackpad lighting powered by Razer Chroma™
    Razer™ Synapse enabled with programmable keyboard, trackpad, backlighting, fan control, and overlocking
    Kensington® Security Slot
    Trusted Platform Module (TPM 2.0) security chip embedded
    Compact 250W power adapter
    Built-in 99Wh rechargeable lithium-ion polymer battery
    0.88” / 22.5mm (Height) x 16.7” / 424mm (Width) x 11” / 281mm (Depth)
    7.89 lbs / 3.58kg
    Darkhan and Vistar Shook like this.
  2. shoespc
    My guess is 5/14 for release date, anyone else care to estimate?
  3. slimjim8201
    slimjim8201 Notebook Consultant
    Preordered one for work through HID this week.
    shoespc likes this.
  4. Niwoo
    Niwoo Notebook Enthusiast
    Really hoping that it comes before May...
    shoespc likes this.
  5. shoespc
    HIDevo has a good reputatation let us know when you get it in. My top two recommendations are to undervolt the CPU and split the raid. If you call Razer support after getting the blade they will send you a win10 USB drive for free to re-image with.
  6. fflyAnml360
    fflyAnml360 Notebook Enthusiast
    Noticed the premium for HIDevolution RBP V2 over razer' website.
    What extra features/service are you getting?
    shoespc likes this.
  7. slimjim8201
    I'm having HID split the raid. The rest is going to be left alone. Curious to see if kaby lake is more thermally efficient than skylake.
    shoespc likes this.
  8. johnnobts
    johnnobts Notebook Deity
    good luck with telling people not to chime in about the "1080 being a 1070." Pretty much gave up on the Blade Pro Owners lounge because of those people.
    shoespc likes this.
  9. shoespc
    For the 2017/2016 RBP you must own the Notepal U3+ aluminum laptop stand which is extremely effective at allowing fresh air intake from the bottom of the laptop and dispersing heat. I bought a few different plastic stands that fit well enough but did not actually reduce temps sustainably.
    Without a stand the RBP does fine but for long sessions of gaming or cpu intensive tasks having a laptop stand is a good idea.
    With our without the fans attached it will keep it much cooler and lessen fan noise overall for $35.
    http://a.co/6KSP27v
  10. GTO_PAO11
    GTO_PAO11 Notebook Deity
    If I play games like Street Fighter V for a long time, do I still need a stand?
