Razer Blade Pro 17 2080 Max Q Vbios
Discussion in 'Razer' started by Hackintoshihope, Jul 19, 2019.
  1. seanwee
    seanwee Father of laptop shunt modding
    The GS75 has the strongest cooling system out of all thin and light laptops (Gs, zephyrus, blade 15, aero) and even surpassing some medium sized ones like the blade 17 and M15R2.
    And yes, you "could" use liquid metal but that'll be like intentionally spilling LM on your motherboard. It's far too risky. How are you going to make it stay in place when you put back the laptop?
  2. Hackintoshihope
    I wouldn’t be able to but I’d be able to least set the laptop in a very very stable position on a desk and run tests while the back plate was off to see if I was getting performance gains within temperatures tolerances.
  3. seanwee
    I'm not sure exactly how you'd go about doing that but before that make sure your blade is at least LMed on the gpu as well.
    @ryzeki is using paste and temps are not good for him.
  4. Hackintoshihope
    You could prop and hold the laptop upside down with it running connected either to a monitor or viewing the screen remotely (with something like Chrome Remote Desktop) as long as the shunts would be facing me and not in the underside of the board.
  5. Joikansai
    Joikansai Notebook Deity
    Guys this result is crazy and it’s i think Blade 15. It’s impossible TB3 egpu setting since no way 2080ti surpasses 25K graphics score. Yeah nowaday 3Dmark is full of questions, is this some kind next level bios tweak;)
    https://www.3dmark.com/fs/20708485
  6. Porter
    Porter Notebook Virtuoso
    I especially like the 145k fps on test 2
    Joikansai likes this.
  7. seanwee
    Its a glitched test, you can request a takedown of that score.
    Just like those 100k+ cinebench r15 scores on a ryzen 3600
    Darkhan likes this.
  8. Joikansai
    He/she:vbbiggrin: dominate the top three on that class 2nd and 3rd place seems fine. Nowadays due this and that, like egpu bios tweaks, cross flashing, 3Dmark is not reliable source to compare performance anymore, they should make better filter.
    Darkhan likes this.
  9. seanwee
    Yes, I have the highest timespy score for i7-9750H and 2080 Max-q laptops but the top 4 spots are taken by an asshat running a 2080ti razer egpu.
  10. Joikansai
    I see, I had 2080ti with 8750H but yours is a lot better it’s due TB3 bandwidth limitation and penalty, especially on dx11 Firestrike it is a lot worse than dx12 Timespy, interesting though that he can beat you there’s always something new like it.
