Razer Blade Pro 17 2080 Max Q Vbios
Discussion in 'Razer' started by Hackintoshihope, Jul 19, 2019.
  1. Raidriar
    Raidriar ლ(ಠ益ಠლ)
    Have you hackintoshed your blade?
  2. Hackintoshihope
    No I haven’t done that in years. The most recent hackintosh was with VMware. And with current NVIDIA relations with MacOS it’d be difficult.
  3. chinocochino
    chinocochino Newbie
    I tried flashing this on my RB15 8750h 2080mq but it's not going above 93w.
  4. Hackintoshihope
    Compare 3D mark scores our machines can’t handle much more power but it can sustain higher power for longer.
  5. chinocochino
    chinocochino Newbie
    You were able to peak over 100w though but I was only able to peak at 93w. My original 90w bios peaked higher at 97w. But I am hitting Performance Limit - Power on both bios. Is that the reason?
  6. wtferrell
    wtferrell Notebook Evangelist
    Are all the RBPs coming w a 90W vbios? So when mine comes tomorrow, nothing more needed?
  7. Hackintoshihope
    Incorrect some come with 80 or some come with 90 and the Blade Pro has a 90-100W bios (allows for a little higher clocks while gaming)!
  8. Joikansai
    Joikansai Notebook Deity
    To be more accurate Blade 15 mid 2019 comes with weird 80 watt, but users flash the early 2019 90 watt without any issue. 2018 1070 and early 2019 (8750H) are 90 watt on every gpu model, Blade Pro 2070 and 2080maxq use 100 watt tdp maybe more since I saw peak 140 watt on 2080maxq.
    run some graphics benchmarks while opening HWinfo64 you’ll see the gpu tdp on your model.
  9. chinocochino
    chinocochino Newbie
    Hackintoshihope, did you end up keeping the RB17 Pro vbios or did you change back to the 90w?
  10. Hackintoshihope
    Kept it haven't noticed any ill effects other then the one time when tweaking overclocks initially a power related shutdown.
