Razer Blade Pro 17 2080 Max Q Vbios
Discussion in 'Razer' started by Hackintoshihope, Jul 19, 2019.
  1. rinneh
    rinneh Notebook Prophet
    That is only since pascal and not on all models, there are laptops where it has been unlocked. But even unlocking it in bios doesnt seem to do anything from what I can gather when it comes to MaxQ.
  2. amihail91
    amihail91 Notebook Consultant
    But the question still remains: am I losing FPS letting my card hit into the PL and remain unstable? Surely I should undervolt it to hit 85w max so it's more stable?
  3. rinneh
    Nope, no GPU stays perfectly stable with its clock and it is also dependent on whats on screen. Undervolting can mean in this case that it cant boost as high to begin with and start power limiting at 85w.
  4. amihail91
    Now I'm more confused than ever o_O
    What benefits am I gaining from messing with the voltage curve in Afterburner?
  5. seanwee
    seanwee Notebook Evangelist
    You will be getting the same performance but better temps since you will be running lower voltages.
    It's similar to overclocking but instead of increasing clocks at a set voltage, you are decreasing voltage at a set clock.
  6. rinneh
    It can go 2 ways, if your GPU is abl eto run at lower voltage, you will basically undervolt your GPU and in return the same performance with lower temps. But if the GPU notices that it cannot keep its clocks at said voltages, it will start downclocking. Thus the undervolt will act as a new power limit. Testing this is a lot of trial and error. It doesnt help that clockspeeds on current Nvidia GPU's fluctuate quite a bit.
  7. Makyura
    Makyura Notebook Consultant
    The one I flashed is exactly the one you posted at page 4 or something alike.
    He said that, but than mentioned that it wouldn't be the case as he was throttling even in freezer.
    I may try reinstalling Synapse just in case some update is then provided to me somehow, as @Hackintoshihope mentioned some update after his RBP vBios flash, I think.
  8. Hackintoshihope
    Bios 1.04 allowed me the constant 100W power draw while out of the freezer with synapse high performance mode.
  9. Makyura
    My unit was produced in August 2019, it came with everything updated BIOS wise; Synapse isn't pushing updates also. I don't know what'up with my unit then.
  10. Chris_OC
    Chris_OC Newbie
    can you please send me the 190W and maybe the 150W and 100W BIOS, too.
    That would be really nice. I have a RB15 with 2080:)
    I´ll post my results and of course make a donation
