Razer Blade Pro 17 2080 Max Q Vbios
Discussion in 'Razer' started by Hackintoshihope, Jul 19, 2019.
  1. Hackintoshihope
    230W is so we are getting pretty close. It should pull more technically (some have said they can go past spec) but seems like I’m hitting power limit on my brick. So it is possible you should get a little more performance? I think you've got a larger power brick?
  2. seanwee
    seanwee Notebook Deity
    Unfortunately not, mine is 230w.
  3. seanwee
  4. seanwee
    Metro exodus benchmark with the RTX preset got a nice boost from 52.34 to 56.37
    Since Ray tracing is known to like fast memory I guess this mod gives a boost where its needed most.
    I dialed back to +1200mhz mhz for now, at +1500mhz there is a performance drop. Probably due to error correction.
  5. Hackintoshihope
    This is inline with what I am now getting I get a few hundred points more at 23,500 but you are getting a nice boost.
    This the score is with a +750MHz
    https://www.3dmark.com/fs/20412171
    This is the score with a +1040MHz and a box fan blowing underneath
    https://www.3dmark.com/fs/20413173
    Also usually stability in all titles with Samsung GDDR6 is about +1000MHz to 1100MHz
  6. seanwee
    Increased my ram frequency back up to 3466mhz. +190core +1200 memory
  7. Hackintoshihope
    Are you using XMP?
  8. seanwee
    No. Msi laptops natively support overclocking.
  9. Hackintoshihope
    I’ve enabled memory overclocking on my Razer but I can’t get anything to stick. I might need to get some better modules. It’s so funny that Razer locks down xmp in the bios lol. It was easy to enable but such a silly thing to do.
  10. amihail91
    amihail91 Notebook Evangelist
    How are you getting into the Memory Overclock menu? I've tried everything BIOS mod wise on this RB15.
