Razer Blade Pro 17 2021 RTX 3000
Discussion in 'Razer' started by Joikansai, Feb 1, 2021.
  1. seanwee
    seanwee Father of laptop shunt modding
    It may be due to how dynamic boost works so the "130" could be 100+30w that dynamically adjusts based on the cpu load.
  2. shardey
    shardey Notebook Enthusiast
    I’m going to hook my power adapter to a Killawatt and see what sort of power consumption I see.
    I need to unlock my bios and undervolt this hot 10875 and see if that improves my score.
  3. MagillaGorilla
    MagillaGorilla Notebook Consultant
  4. shardey
  5. ZeroBarrier
    ZeroBarrier Notebook Geek
    Most likely losses usb-c to DP functionality.
  6. shardey
    Loses more than that. If I switch my settings to dedicated and bypassing optimus, it completely disables the built in display and an external monitor needs to be used.
    I’ll stick to the 130W 3080 from the mid 2021 17”.
  7. MagillaGorilla
    I’ve used this vbios on the muxless 11900h model and the 11800h with mux.. never lost main display.
    HDMI works too, never tested USBC
    Guess you confirmed it doesn’t work for the 17” model with mux.. Not sure why that would be the case though as I’ve seen ppl flash diff Vbios’es just fine
  8. Loukiz
    Loukiz Newbie
    Hello!
    I'm new to this forum and I recently purchased a razer Blade 14 with the RTX 3080.
    I read that you are able to Flash the vbios of the Blade 17 with RTX 3070 on the Razer Blade 14 (3070). Unfortunately the Razer Blade 17 with RTX 3080 has 16 GB or 8 GB of VRAM depending on the display.
    I only could find the vbios of the Blade 17 3080 with 16 GB of VRAM and I don't know if I could safely flash that on the Blade 14 with 8GB 3080. Does anyone happen to know the answer to this or could provide the vbios of the Blade 17 with RTX 3080 and 8GB of vram?
    Thank you very much and have a great week!
  9. mnd99
    mnd99 Notebook Consultant
    Hello Blade 17 owners,
    How are the speakers? Audio quality? Does the sound get loud enough to "hide" the fan noise? Any chance anyone know how the audio compares to the Asus Zephyrus S17?
  10. shardey
    I came from a 16” MacBook so I can want expecting that tier of quality for the speakers. However, the speakers get plenty loud and are definitely better than a 17” Maingear Vector and a Asus Strix Advantage without a doubt.
    The speakers are more than capable of overpowering the fans where the previous 2 laptops I mentioned couldn’t without sounding poor.
    mnd99 likes this.
