Razer Blade Owner's Lounge
Discussion in 'Razer' started by johnnobts, Feb 3, 2012.
  1. Mitchell Gore
    Mitchell Gore Newbie
    Wow it seemed to help I think... It went to 150+fps but only on non full screen. On full screen it is still limited to 40 fps
  2. hfm
    hfm Notebook Prophet
    See if there's a vsync setting in Minecraft.
    Actually, it might be because it's running at 3200x1800 when full screen. Can you force the full screen resolution?
  3. Mitchell Gore
    I have the vsync off and it still only runs at 30-45 fps at full screen. Im not sure how i would go about forcing the full screen resolution.
  4. hfm
    Might be that you have to change your desktop resolution. I'm
    You might just have to change your desktop resolution to 1080p or something before playing it and switch it back afterward. If you don't see a setting for it, that's probably it.
  5. Sumanji
    Sumanji Notebook Enthusiast
    Quick question - for the Blade 14" (2013), is 1.01 the latest BIOS version?
    Cheers,
    Su
  6. Wask
    Wask Notebook Consultant
    Razerblade 2012... Will this be able to upgrade to windows 10. I have recently had a update to synapse which said it was 100% compatible... Is this correct? Just I have all my DJ/Pro Audio software/hardware on it and don't want to eff anything up...
  7. Wask
    Well everything seems hunky dory Win 10 is really cool...
  8. Trigger10
    Trigger10 Notebook Enthusiast
    Quick question - I have the 2015 256gb (3K) version of the Blade and am loving it. However since I decided to also make this my work laptop, I'm going to start running into storage issues sooner rather than later, especially as I add more games. Can I manually add another SSD to this particular model, or does it not have the extra slot for it?
  9. Eason
    Eason Notebook Virtuoso
    Only 1 m.2 ssd unfortunately. Try cleaning up the win sxs folder.
  10. hfm
    I created a thread about upgrading, sorry on my phone I don't have a link handy.
