Razer Blade BIOS
Discussion in 'Razer' started by pbhenry3, Aug 4, 2017.
  1. Hackintoshihope
  2. t456
    They're all Chinese, but quality can obviously differ. The very cheap stuff is often made with very soft plastics, best known from 'tools included' items such as with lcd/digitizer replacements for smartphones.
    If frequent reflashing is expected then you might opt for eeprom sockets:
    Main thing is that you can keep a separate, stock chip at hand for easy, no-programming recovery. Neither do you have to shutdown the system prior to flashing; on boot the (v)bios, ec and me are 'shadowed' (copied to RAM) and the system will run from those copies. With the socket you can simply pull the eeprom from the live system, flash it with programmer+adapter (200mil), drop it back, reboot and check your mods.
    Unfortunately, these will not work as-is for 150mil vbios eeproms; have to mod its footprint first (and use 200mil chips henceforth). If anyone manages to find a 150mil equivalent then don't keep that information to yourself, please :vboops: .
    Nuke33 and Vasudev like this.
  3. Sumanji
    Sumanji Notebook Enthusiast
    If you still need this and can give me instructions on how to dump the BIOS, I can do this for you.
    Cheers,
    Su
    Nuke33 and Vistar Shook like this.
  4. pbhenry3
    pbhenry3 Company Representative
    hey bud, I actually have the bios for that one now. however, I am working on a modified bios/modified vbios combined on this one since the vbios is embedded in system bios. I need a bit more information to modify this, if you'd like to help can you please download "GPU-Z" and send me a screenshot of the main tab, put some load on the gpu and also send me a screenshot of the "sensor" tab. You would of course have access to the mod once it is complete.
    Vasudev, Nuke33 and Vistar Shook like this.
  5. warhouse
    warhouse Newbie
    Hey Nuke, could you post the bios again? or anyone if they have it?? Thanks!
  6. Nuke33
    Nuke33 Notebook Consultant
  7. Kajetan Kasprowicz
    Kajetan Kasprowicz Newbie
    Hey Nuke, is there any chance that you have a BIOS (.rom) for Blade 2016 FHD skylake gtx1060, version before spectre and meltdown patches?
    Thanks in the advance.
  8. ngvuanh
    ngvuanh Notebook Deity
    Vistar Shook likes this.
  9. Sumanji
    Hi @pbhenry3
    Hoping this is better late than never...! Screenshots below :)
    Cheers,
    Su
