Razer Blade BIOS
Discussion in 'Razer' started by pbhenry3, Aug 4, 2017.
  1. Hackintoshihope
    I’ve used the programmer they use and test clip in that thread on my razer and it works flawlessly. Also the China test clips suck... there is on in there from amazon that is superb and allows a proper connection to the bios chips. The Chinese ones constantly break.
  2. bloodhawk
    bloodhawk Derailer of threads.
    Yeah the newer TL866CS' have that issue. Which seems to be because of over sensitive over current protection. It's easy to over ride that using a hard mod to the programmer though.
    OR
    You can use the CoRight Skypro. Way faster and works like a charm for inline flashing. Slightly cheaper as well. :D
    Vistar Shook and Hackintoshihope like this.
  3. pbhenry3
    pbhenry3 Company Representative
    Could've possibly been an issue with my test clips then. I'll try looking for a better set on amazon. thanks :)
  4. Hackintoshihope
    @bloodhawk must be on to something, I use the skypro. However again look through the thread I linked and you should find some equipment to help you along with repairs and tweaking.
    Vasudev, Vistar Shook and pbhenry3 like this.
  5. bloodhawk
  6. pbhenry3
    you guys seem to have a lot of experience with programmers, a lot of great info.
    Vasudev, bloodhawk and Vistar Shook like this.
  7. Hackintoshihope
    Vistar Shook, Nuke33 and pbhenry3 like this.
  8. Nuke33
    Nuke33 Notebook Consultant
    Very nice info @bloodhawk @Hackintoshihope
    It is always very complicated to flash routers with SPI flash multiple times. That way would make test flashing a bootloader much easier.
    Does the Skypro also support 256mbit+ Quad SPI chips like the Spansion S25FL256S?
    Edit: Never mind, I found the supported chips list. Support is very extensive. I like it.
  9. Nuke33
    I see, i hate nvidias policies :mad:
    I think it is safe to say Razer won´t sign a mod :)
    Is there a way to obtain a means of signing it yourself without signing any NDA?
    Vasudev and bloodhawk like this.
  10. ngvuanh
    ngvuanh Notebook Deity
