Razer Blade Advanced (RTX 2070, 8750H) Stuck at 2.9GHz?
Discussion in 'Razer' started by Braxton, May 21, 2019.
  1. Braxton
    Braxton Newbie
    Yeah my CPU runs in the 90s even with all of my adjustments and so forth.
  2. Wishmaker
    Wishmaker BBQ Expert
    Do you have a bit of air in the room for the cooling to do it’s job ? I had to open a window a few times to cooldown my laptop .
    Sent from my iPhone using Tapatalk Pro
  3. Joikansai
    Joikansai Notebook Deity
    Upload your sensor like using HWinfo64 like this, while running the game like this
    If difference between cores huge like 10degrees on gaming means heat sink doesn’t cool properly like uneven or gap, try repasting again and maybe add some pad. That’s notebookcheck stock paste running max stress test which’s equal with gaming imo.
    Probably bios setting issue, update would be needed, I remember on 2018 model there was also similar issues power consumption after waking up and solved with bios update.
