Razer Blade 2018 (GTX 1070) + egpu + RTX 2080ti + 240hz FHD
Discussion in 'Razer' started by Makyura, Aug 9, 2019.
  1. Makyura
    Makyura Notebook Consultant
    Hello everyone, as I got a new job with a pretty good salary, I decided to upgrade my existing rig; I currently own a Razer Blade 2018 (i7 8750H & Gtx 1070) and a FHD 144hz 1ms monitor.
    I was considering getting a Razer Core v2 to plug my mouse and keyboard in and have it, together with a 2080ti, pass the signal to a new FHD 240hz screen.
    Would that be enough to have something as close as possible to 240fps in Apex, Destiny 2, PUBG, Fortnite, Overwatch and so on?
    I'm planning to to run them at lowest settings and, if required, underscaled textures just for the sake of competitive bonus frames per second.
    I know that egpu would bottleneck, but 6C 12T are probably going to keep things a bit balanced, aren't they?
    Does anyone have the chance to test this for me? I can only find 4k data.
    Also, considering how cooler the notebook will run, I might as well force the CPU to stay on turbo 24/7.
    Sorry for asking something people might have already talked about, but it has been hard for me to gather information on FHD 240hz egpu rigs.
    Thank you in advance!
  2. rinneh
    rinneh Notebook Prophet
    The TB3 interface will severely bottleneck the 2080ti to a point where it is no use. Dont waste your money on it. The 6core CPU doesnt matter, the performance can just not be called upon in games.
    DrewN likes this.
  3. Makyura
    A 2080ti would eat Apex min settings at breakfast tho, so how many FPS should I expect through a TB3 is the real question.
    Thanks for your view on the matter by the way
  4. rinneh
    Its exactly at minimum settings where the bottleneck starts to appear.
    A 2080TI barely performs betters than a laptop 1080 in most cases and in some others it performs even less.
    In theory the bottleneck shouldnt be as large since it is basically a PCI express 3.0 4X slo.Which should give the performance mentioned here https://www.techpowerup.com/review/nvidia-geforce-rtx-2080-ti-pci-express-scaling/6.html
    But the TB3 port is using PCH lanes and not direct CPU lanes which causes a huge performance drop and there is also the TB3 communication overhead. So in the end you pay a solid 1000~1200USD for an extremely measly upgrade compared to the internal 1070MQ that you have now.
    DrewN and rb6freak like this.
  5. Muezick
    Muezick Notebook Consultant
    Yeah TB3 e-GPU setups aint where it should be yet, it's for folks who have MX150s and 1050's in their laptops. You should just sell that laptop, and with the extra money, instead of a core v2/2080 ti, buy an actual rtx2080 rb15 2019 edition advanced model. the performance boost will be MUCH better. also the 9750h is a great CPU.
    I am seriously hoping a new revision of TB3 comes out with PCIe 4.0 lanes that actually dedicates directly to the CPU lanes instead of this round about B.S. they have now. Totally worthless in more powerful laptops, or at the very least, not even close to worth it with the cost ratio.
  6. rb6freak
    rb6freak Notebook Enthusiast
    This. Pushing 240 fps over Thunderbolt3 just isn't going to happen, even in CSGO at 1080p. When you crank graphics settings to max and go for the highest resolution possible, that's when the bottleneck starts to minimize. This is because you're now in a low enough FPS range that you can push all that data through the Thunderbolt line.
  7. Hackintoshihope
    High Resolution gaming is what benefit you are going to get out of an EGPU and not huge FPS numbers. The issue is people like me don't exist that much anymore, I like the highest quality a game can offer (4K, Max Settings, 60FPS) although it would surely help you in this regard with an EGPU the issue is you are wanting to play games at low resolution with huge FPS numbers which drains the bandwidth that TB3 offers. Hope this gives a bit more clarity as to why you are seeing 4K testing rather than lower resolution.
    Sadly you are wrong the EGPU setup he is talking about would be a drastic improvement over a 1070 Max Q, I know first hand as my girlfriend uses one with her MSI laptop and when paired with an RTX 2080 TI it gets double the FPS and graphical fidelity in FFXIV at 4k then with her 1070 Max Q.
    seanwee likes this.
  8. rinneh
    The numbers dont lie, they are visible in the video. You are presenting an usecase which is the only usable use case for a TB3 egpu now (the alienware solution doesnt have this downgrade). Just as you stated as well, the bottleneck is the largest at high cpu loads.
    Apart from that some rare games arent affected by the bottleneck but the large majority are. So sadly you are leaving that part out of the equation. Youtube is filled with similar videos as I have posted earlier and i have my fair share of experiences with egpus as well. It is not just with high framerate low res gaming. 1440P high settings is already enough to show the problems.
    Wouldnt surprise me that you have fairly okay results as well because the laptop you are talking about (1070mq must be of the GS series) is thermally constrained so by offloading heat it starts to run better as well nerxt to that 1 odd game that you mention.In general use, a 2080ti just doesnt perform in TB3 and thats a fact.
    A nice discussion surrounding the performance drops can be found here
    http://forum.notebookreview.com/threads/clevo-egpu-results.825412/
  9. Hackintoshihope
    You are missing a huge point you lose an extreme amount of performance when you also use the internal monitor. I have my girlfriend setup using an external monitor more like a desktop setup thus performance loss is in the 15-25% range as we are not dealing with internal GPU overhead. Although you have a desire to prove me wrong the facts are at 4K the performance of a 1070 Max Q can never attain results that are playable at max settings. Regardless this is not what the OP wanted, the OP wanted max FPS at lower resolution which we both agree doesn't work with TB3.
    RTX 2080 Super 24% Performance Penalty over TB3
    Evidence: NoteBookCheck
    Laughable GTX 1070 Max Q Performance a full 35.59% worse than above however it is running in spec not as you said "overheating".
    As I said above your claim that a 1070 Max Q would perform the same as an RTX 2080 TI let alone albeit a weaker RTX 2080 Super is false.
    Also this is worst case scenario as this is Fire Strike and it is not in 4K and we are goign to see the worst performance hit in this benchmark our scores only improve in Fire Strike Extreme due to lower bandwidth requirements!
    seanwee likes this.
  10. rinneh
    If you know my history on thi sforum you know that I have run an external eGPU setup for years. I am well known with the limitation. Firestrike is not an indication of performance fo eGPU's because it simpply doesnt bottleneck and flatters the performance results.
    Again I posted a video with real life results in situations not focused on getting the highest FPS possible on low settings.
    I dont rhave my eGPU setup anymore or else I would have made recordings specially for you to see. BUt I ditched it because poor performance.
