Razer Blade 2016 Fan Control success
Discussion in 'Razer' started by kamueone, Jun 11, 2016.
  1. kamueone
    kamueone Notebook Enthusiast
    hi everyone
    i can now freely control the fan speed of the Razer Blade 2016. it should work for other versions,too.
    The Fan Speed can be dropped, but completly stopping it will be difficult.
    so this ist how i control the Fans:
    You will need:
    - Notebook Fancontrol
    https://github.com/hirschmann/nbfc/releases/download/1.4.2/NoteBookFanControl.1.4.2.setup.exe
    - Razer Blade 2016.xml ( config file )
    http://s000.tinyupload.com/index.php?file_id=00017442882981417611
    1. Install Notebook Fancontrol
    2. Put the Razer Blade 2016.xml file to --> Program Files (x86)\NoteBook FanControl\Configs
    3. Start the Program
    4. Choose the Pofile
    5. Enjoy
    I put it to Auto all the time. Now on not so demanding tasks the Fans are a little bit more silent.
    The temperature is visible but the Fan speed is not visible yet
    If someone want to optimize it, just read the howto for the NotebookFanControl app.
    Thx to the programmer for this great app.
    weslaw likes this.
  2. Makyura
    Makyura Notebook Consultant
    Doesn't work on 2015 blade, attached a SS of what's showing up, window option and error message you get by applying the profile.
    Edit: after a random BSOD it rebooted and started working.
    I gotta love you my friend.
  3. kamueone
    i am happy to hear that.
    hope this spreades fast and will be optimized soon
  4. Makyura
  5. kamueone
    i am very happy i could help. The profile was not that hard to make. some trial an faliure and its done. i hope other people will like it like you do. thx for the kind words.
    Vistar Shook likes this.
  6. weslaw
    weslaw Notebook Enthusiast
    Just tried it on my 2014 Blade and it works!
    The only thing that doesn't seem to work is the Current Fan Speed reading, but setting the Target Fan Speed works just fine.
    Amazing! Thank you!
    Update* - I had to uninstall the program, for some reason it was messing with my battery, it was giving me "undetected battery" while running off battery power. Or it would be at 80%, then suddenly drop down to 2%, forcing the laptop to go into sleep mode, only to boot up right after and be at 80% again.
    Going to have to hold off using this until some more updates/info.
  7. kamueone
  8. dashmoopies
    dashmoopies Newbie
    Hi there! I tried to run this on my 2016 Razer Blade (the new one with the GTX 1060) and it's acting a little weird. When I first run it, it works perfectly, the fans quiet down and everything. After a couple minutes it just goes to sleep randomly, then when it comes back the fans are louder than before and I have no control over it. Razer Synapse can still control the fans but the program you mentioned only starts working when I set it to like 80% or higher. Is there any (more agressive) options I can do to take over the fan speed than that program?
  9. dashmoopies
    dashmoopies Newbie
    Were the fans louder than before after it woke back up? I think I'm having the same issue, it randomly slept after having the program. It's such a nice program but a shame that there are small issues like this.
  10. ryajso
    ryajso Notebook Consultant
    My fans just go straight to max when I run the program. I'm using a 2014 Blade for reference.
