Razer Blade 2013 upgraded screen
Discussion in 'Razer' started by PRSnow, May 29, 2014.
  1. ApachePrime
    ApachePrime Notebook Enthusiast
    Warranty is voided anyway, it's been opened up.
  2. PRSnow
    PRSnow Notebook Enthusiast
    Very true, although they probably won't even notice it's been disassembled because I made sure to make it look as though it was completely untouched after I finished.
  3. Dinamis
    Dinamis Newbie
    i cant believe that old screen is such a sh!t
  4. PRSnow
    It's the worst! It ruined an otherwise almost perfect laptop.
  5. ranix78
    ranix78 Notebook Enthusiast
    can you please give the exact reference of your screen? or can someone advice me the best screen to change on my razer ? I sadly brok m screen, So iI have to change, I will change it fo something better....
  6. ranix78
    no idea of the best panel 1600/900 compatoble with te razer?
    I really need to buy one...I will deeply apreciate if someone can give me a link to a good screen or a link where I can find information and make my choice...
  7. PRSnow
    LP140WD2-TLE2
    The screen is not a direct replacement though. You will need to partially disassemble it in order to fit it into the laptop. I broke two screens before getting it just right because it was so difficult.
    And try to obtain a genuine LG screen if you plan on trying this yourself. Most of these models sold are aftermarket Chinese ones but only the LGs have high backlighting brightness and the best color.
    Good luck. This mod is extremely difficult.
  8. ranix78
    I found the g screen, going to order 2.
    Can you please write some kind of step by step tutorial about what should d and what I should not do in order to make it complete?
    I will deeply appreciate it. My screen is broken so I have no choice.
    May be if you have some pictures...
    So the lg is the best replacement possible/ no other screen can provide even better result?
    searching internet about 14 inch panel test and no result...
  9. ranix78
  10. PRSnow
    That screen might work, but its viewing angles aren't as wide and most importantly it does not have as high a color gamut. Meaning it produces colors less accurately vs the one I used.
