Razer Blade 15 VS MSI GS65
Discussion in 'What Notebook Should I Buy?' started by Grxzz, Mar 30, 2019.
Wich would you buy?
  1. Razer blade 15
  2. Msi gs65
Results are only viewable after voting.
  1. stamar
    stamar Notebook Prophet
    jrey
    anything different about a clevo 970 gpuz readout that might make it not work the same as you did?
  2. JRey
    JRey Notebook Evangelist
    I don’t understand your question.
    Are you asking about GPU flashing?
  3. stamar
    Yes I am I asked is there anythibg you see in thr gpuz readout different than your hardware
  4. JRey
    You’re using a RTX 2070 Max-Q while I have a 2080 Max-Q.
  5. knibbler
    knibbler Notebook Evangelist
    Double the battery life? Reviews show the MSI is better but not by alot.
    These are some good points though. If you are a very advanced user who is willing to mod your bios and flash your vbios voiding the MSI warranty...then the MSI might be a better choice ingoring the floppy build quality.
    For the other 95% of people.....
    Hope this helps!
  6. stamar
    I'm not aware of why that would void your warranty if they did i would sue
    You own the hardware and the bios its yours to use as you wish
    But Even more important flash it back and there is no proof it ever happened .
    Poor advice scare tactic.
    Flashing takes you 1 minute.
    Even the bs that you can brick your gpu is totally bs theres functionally no cases if this happening
    Flashing the systen bios is so much more dangerous. You can flash your vbios 20 tikes a day and if itbfailed flash the original on
    That's what its meant for I'm bot sure when the technical level of laptop users fell to where some are scared to update bios
    Wow very advanced user just shake my head.
    Basic computer enthusiast.
