Razer Blade 15 Studio
Discussion in 'Razer' started by Metiiin, Sep 21, 2020.
  1. Metiiin
    Metiiin Newbie
    Hi all,
    Could someone direct me to some links for unlocking the bios, PL, and such for this model?
    (Blade 15 Studio Edition - Late 2019 - RTX5000)
    With the latest windows there is no CsEnabled and I can't find any threads regarding my specific model.
  2. wireproof
    wireproof Notebook Guru
    Might need a CH341A programmer to flash the bios chip directly on the motherboard. Use AsProgrammer to read the BIOS then edit in AMIBCP 5 and then flash with AsProgrammer. You’ll need to enable the overclocking menus in AMIBCP and there’s a few forums here with the process on which ones to enable.
  3. Joikansai
    Joikansai Notebook Deity
    For removing PL it’s literally under your this thread, since it’s on cpu side and working on 15 8750H, stealth 8550, 8656U and current stealth icelake 1065g7, i think it’ll work regardless the model including also on your 9750H. For overclocking menu try changing it on AMIBCP menu, on my 8750H 2018 model it’s locked and apparently need doing this tweak but on early 2019 a user back then told me it’s unlockable by simply changing the value to user from default.
    wireproof likes this.
  4. Metiiin
    Metiiin Newbie
    The registry locations no longer exist on the most recent update of windows. Are you certain that I can skip the regedit step and safely achieve the same results?
  5. Metiiin
    Metiiin Newbie
    This would definitely make for a fun project, however don't think this route would be available for me currently.
  6. wireproof
    The registry settings I believe are for Razer Synapse, so I'm not sure how relevant it is for your model. Your BIOS may not be locked so you can try to just read the bios, modify it, and then reflash from inside windows. But the i7-10875 model is locked so I had to use the CH341A
    Sent from my SM-N960U1 using Tapatalk
  7. Joikansai
    I don’t even care about that, straigh flash the bios set imon values similar with the thread on 8656U and icelake 1065g7, both same results no power limitation and all core boost to its max, with extra thermal comes as trade off. It’s fun having max scores on synthetic benchmarks like 3Dmark or cinebench but for gaming or long time cpu heavy task, you may want limiting the boost per throttlestop.
  8. wireproof
    The battery life on my Razer 2020 Advanced was horrible, barely squeezing out an hour and I was able to set IMON to -50 and undervolt to -65 in bios and then got about 3.5-4 hours of battery life and when I plug it in synapse automatically changes and my Cinebench R20 shoots between 2900 and 3200 depending on my thermal situation (cooling pad vs table) the only thing that’s not “automatic” is the refresh rate from 60 on battery to 300 on ac. Worth using a CH341A IMHO
    Joikansai likes this.
