Razer Blade 15 RTX update
Discussion in 'Razer' started by Joikansai, Jan 7, 2019.
  1. HeavyUser
    HeavyUser Notebook Guru
    OSD Precision XOC worked, thanks.
    Joikansai likes this.
  2. HeavyUser
    Any of you with the 2080 max q have the game Middle Earth: Shadow of War? I was wondering if you could run the in game benchmark for me and post your results.
    I can't seem to get past 105fps score on Ultra, it seems pretty low compared to benchmarks online.
  3. Joikansai
    Joikansai Notebook Deity
    Try changing maybe sync setting from adaptive...not quite sure since I uninstalled it already, and not know quite sure on Rtx Blade but on last 1070 model on default setting it was also lower than average, I changed one setting and it goes to normal (higher) FPS.
  4. mario64
    mario64 Notebook Evangelist
    I am pleasantly surprised by how quiet the 2080MQ is. Razer is known for loud whiny fans but not in this machine. You will hear them but it’s not bothersome and not over game audio
  5. jasonj566
    jasonj566 Notebook Consultant
    I bought a new razer rtx 2080, and upgraded HD to Samsung 970 pro, is there a list of drivers, bios somewhere? I noticed on razer.com it didn't have any uploaded there yet
  6. Joikansai
    You may want to wait till they upload it. You can fresh install windows and install manually drivers from each vendor like nvidia and intel, but bios, firmware and newest Synapse (Blade Rtx Synapse 3 is a bit different on looks and mode, there’s new creator mode beside traditional balanced and gaming mode, and rpm is higher up to 5300 I think vs before only 5000rpm, this may be hardware related). Though you can try contact support ask for that or maybe try using Synapse all installer from advanced last year after windows clean installation, or clone the original ssd. If those didn’t work you can put back the original ssd again.
    jasonj566 likes this.
  7. IKAS V
    IKAS V Notebook Prophet
  8. HeavyUser
    990mhz with limited usage. 100% usage clock speed stablizies around 1400mhz
    IKAS V and Joikansai like this.
  9. Joikansai
    I’m pretty sure it’s also similar higher tdp gpu 90 Watt one. Did you already surpass 21K graphics score? I think with afterburner it may perform higher.
  10. HeavyUser
    I get around 20300 give or take with the graphics score. I stopped benchmarking as I'm plenty happy with the results from real world gaming.
    IKAS V likes this.
