Razer Blade 15 Late 2019, RTX 2070 and 240Hz BIOS?
Discussion in 'Razer' started by pitha1337, Jan 27, 2020.
  1. pitha1337
    pitha1337 Notebook Evangelist
    Hi everyone,
    I have a new Razer Blade 15 Late 2019 with the RTX 2070 MQ and 240Hz. On the official website I couldn't find any new Firmware/BIOS Updates for the late 2019 Blade. Where can I find the newest Firmware/BIOS Updates for my blade?
  2. pitha1337
    alaskajoel likes this.
  3. childprotectorofthenight
    childprotectorofthenight Notebook Consultant
    Any idea why I get the error. "This firmware tool is for use only with Blade and compatible system. I have the same model as the user above. The Update button is darkened. Can't tap it
  4. pitha1337
    Unfortunately I thought I have a late 2019 Razer but it is an Mid 2019 Razer. Seems like there is no new BIOS for the late 2019 Razer.
    Side note: Flashed by VBIOS to 100W. Now my RTX 2070 MQ with OC is on a level as an 2080 MQ. Very impressive!
  5. Zill
    Zill Notebook Consultant
    Hey, cool to know it worked! I assume you have the 9750H. I'm asking because I'm tempted to try out this bios on my 8750H Blade 15 (early 2019) since I can't get the 2070 to run at 100W after flashing the it with Blade 17 2070MQ 100W vbios... I'm guessing it's the system's firmware stopping it to take advantage it of it, not sure if it'll ket me flash the mid-late 2019 bios though...
    Thanks!
  6. amihail91
    amihail91 Notebook Evangelist
    You can force a BIOS update by extracting their .exe with 7zip into a folder, navigating to that folder and running "FlashAFUWin.bat" as Admin, this is what their little program does under the hood anyway, just silently with no command prompt.
  7. rinneh
    rinneh Notebook Prophet
    You cant just cross flash a total system bios most probably. There are differences between bot systems.
