Razer Blade 15 DGPU
Discussion in 'Razer' started by SUADE8880, May 20, 2020.
  1. SUADE8880
    SUADE8880 Notebook Evangelist
    Is there no option in Synapse for the 2019 Razer Blade 15 to force dedicated gpu only? There is no option like this below....
    Joikansai likes this.
  2. alaskajoel
    alaskajoel Notebook Deity
    In 2019, the 'GPU Mode' option was only available on the Blade Pro 17 4k120 and the Optical Switch Blade 15.
    Early users on Reddit have reported it is also available on the 2020 Blade 15 advanced but not sure about the basic.
    Joikansai and SUADE8880 like this.
  3. SUADE8880
    Well that’s a huge bummer! Do you think it’s hardware or can it be implemented through bios/software later?
  4. alaskajoel
    Unfortunately, this setting requires a hardware mux switch that does not exist on the other Blades. It cannot be implemented via software alone.
    SUADE8880 likes this.
  5. SUADE8880
    I just bought this and is well in my return window I wonder if I should return this for the 2020 model..hmmmm..:confused:
  6. alaskajoel
    If it were me, I would return it unless I got a killer deal. I value a fully switchable GPU a lot. The other features are gravy.
  7. SUADE8880
    Thanks! I will go ahead and return it since it will only cost me $200 more for the latest cpu, 300Hz screen, and of course the switchable GPU.
    alaskajoel likes this.
  8. alaskajoel
    No question $200 would be worth it for me. The resale value alone is probably worth that if you plan to upgrade again in a couple years.
