Razer blade 15 advanced help
Discussion in 'Razer' started by Cerreta28, Jul 26, 2021.
  1. Cerreta28
    Cerreta28 Notebook Evangelist
    Hello I have an issue with the blade 15 advanced 3070 . The WiFi cuts out if you flex the back of the chassis on the top right . I’m guessing it has to do with The antennas are those possible to replace being that they’re behind the screen can you get to them? If you have any other ideas on what it could be that would be helpful as well.
  2. Joikansai
    Joikansai Notebook Deity
    If it’s still new maybe better return it if you suspect it as a hardware failure.
