Razer Blade 15.6" (GTX 1060/1070, 2018 edition) Owner's Lounge
Discussion in 'Razer' started by X33nbat, May 20, 2018.
  1. Darkhan
    Darkhan Notebook Deity
    The part I circled is this the power connector from battery to MB?
    Surely you disconnected the power before taking out the heatsink?
  2. Firebat246
    Firebat246 Notebook Deity
    I always disconnect the power before doing anything "under the hood". My only exception was swapping out the hard drive for the 970 Evo.
  3. Darkhan
    Can you tell though is that the correct connection and does it just pop off and on like a 9V battery cap?
  4. Assault
    Assault Notebook Evangelist
    Yes, and you're exactly right, just pull Up.
    Darkhan likes this.
  5. Firebat246
    Yes and yes!
    Edit: About the battery sorry about that
    Darkhan likes this.
  6. Assault
    This seems to be the best I can do in fortnite's case. Undervolted and clocked down to 3.6ghz on max fans...
    Settings in throttlestop too. Any suggestions?
    Metalocalypse likes this.
  7. Metalocalypse
    Metalocalypse Notebook Guru
    Order my too and now worry about all that problems with throttling. It even possible to play games without fps drop?
  8. Firebat246
    I'm going to be bombarding you guys with feedback after I do all my post thermal paste/pad replacement testing. I use Farcry 5 as my test game as it's fairly demanding. Not that I can't use some other games if people have requests. Will be looking at thermals and clock speeds. Using XTU/TS/Hwinfo64/Afterburner/Precision Xoc as some of my normal OCing/testing apps.
    Joikansai likes this.
  9. xDjinn
    xDjinn Notebook Enthusiast
    Hey so for anyone with the new razerblade do you have any Backlight bleed or IPS glow?
    LGD05C0
  10. Assault
    Hardly, only a couple millimeters on bottom edge only.
