Razer Blade 15 240hz Review Video - Major issues on display
Discussion in 'Razer' started by Joshva, Jul 7, 2019.
  1. Joshva
    Joshva Notebook Consultant
    Hi team,
    I just completed my review of the Razer Blade 15 240hz 2070 model.
    As the title says there are some pretty major issues here that i'd be cautious of if buying. I do like the laptop but i'd recommend taking a look at some of the things I found including blue screening on many units, freezing etc.
    I hope it helps those considering this laptop,
    Josh
  2. rinneh
    rinneh Notebook Prophet
    As said on your reddit thread as well.
    Reinstall your gpu drivers after unisntalling them with DDU would fix your issues with the blue screens etc.So no it is not prone to crashes, it is you not realizing that Nvidia released some faulty drivers some time ago.
    I think this should have been done in the light of doing all the effort to make a review. and ofcourse a laptop that can go up to 240watts of power usage can get hot. but it is not overheating hot.
    There are laws of physics which cannot be broken. It is one of the thinnest and smallest RTX laptops out there, the heat must go somewhere.
  3. notstaamp
    notstaamp Notebook Guru
    does anyone have the oled version ? or can point me to a review of the oled version ? thx
  4. Terreos
    Terreos Notebook Deity
