Razer Blade 15 2070 100Watt Bios
Discussion in 'Razer' started by MezZo_Mix, Sep 13, 2021.
  1. MezZo_Mix
    MezZo_Mix Notebook Guru
    Hello guys,
    since you helped me with the bios hex editor. I need you again, I read on the internet that it is possible to flash the bios of my 2070 80/90Watt on Gaming to a 100Watt bios.
    my question is, do I just need a 2070 max Q 100Watt bios to flash it, or is there more? My 2079 won’t gl above 75C on gaming mode with a 165core/750mem oc.
    In case I mess up can I still flash it back via the integrated GPU or can I brick the blade?
  2. MezZo_Mix
    I’m using a patched nvflash for Turing cards but I still can’t flash the bios from the Blade Pro. Im using a Blade 15 early 2020. Any help?
    I did:
    nvflash --protectofff - no errors
    then
    nvflash -6 2070.rom
    then I get the following error, seen on the second screenshot. I even tried --index=0 2070.rom because of the possibility that the iGPU will conflict but, same error
    https://imgur.com/a/ZcSrwKM
    Edit: so it looks like I need a vbios from a RBP with a 10th gen CPU, right? To make the flash work? Or can I simply edit the vBios? Or even worse does this "trick" won’t work with newer blades?
