Razer Blade 14 digitizer replacement?
Discussion in 'Razer' started by Demis n, Jun 27, 2018.
  1. Demis n
    Demis n Newbie
    I recently broke my Blade's glass. Screen works fine though. It is 2014 model (RZ09-01161E31-R3U1), with QHD screen. I was wondering if there is a way to replace the digitizer only. I cant find any suitable replacement on ebay. Can anyone help me out?
  2. Vistar Shook
    Vistar Shook Notebook Deity
    You can try @pbhenry3 at techworksrepair.com
  3. ngvuanh
    ngvuanh Notebook Deity
    Razer touch panels are glued to LCD, so it is not easy to separate LCD from touch without damaging it. In addition, it's nearly impossible to find touch panel (glass) only even though there was one seller sold his recently.
    Sent from my SGP771 using Tapatalk
  4. Demis n
    Demis n Newbie
    I see. I didn't even know that glass was glued to the LCD. So I guess I will have to replace the entire assembly.. Thanks a lot guys!!
