Razer Blade 14 (7700HQ/1060) beatdown log
Discussion in 'Razer' started by Mobius 1, Apr 26, 2017.
  1. Sopey15
    Sopey15 Notebook Consultant
    I recently picked up a used 2017 Razer Blade with a 7th gen 7700hq processor. It seems to be working well but I noticed that I can not get the processor to idle below 1100mhz and typically it is at 1500mhz. Is this normal? I thought that idle clock speed for the 7700hq should be 800mhz.
    I asked this on reddit and didn't get any responses.
  2. Gebirgskuchen
    Gebirgskuchen Notebook Enthusiast
    Letting it idle over night it CAN reach 55-57° Celsius.
    But now again - without any tasks running - it's idling between 63-65° Celsius, which shouldn't ne normal.
    Even simply opening one tab in Firefox gets the fans to kick in...
    One thing that bothers me as well is the power consumption between 12-15 Watts on IDLE!
  3. Joikansai
    Joikansai Notebook Evangelist
    I think I answered you in Razer forum;)
  4. Gebirgskuchen
    Doesn't help me much.
  5. rinneh
    rinneh Notebook Prophet
    If you have max screen brightness on, using a performance powerprofile, using firefox on your Nvidia gpu instead of intel gpu than all that is normal.
  6. Gebirgskuchen
    I have max brightness on, yes.
    BUT: I'm running on the Windows Balanced Mode, without Turbo Boost (90%),
    I use Firefox with the Intel 630 HD. I checked the nVidia Control Panel, saying that ONLY the Intel 630 HD is used for everything/every program (checked in global settings).
    And I also undervolted the CPU by 130mV.
    I even uninstalled Razer Synapse.
  7. rinneh
    What apps are running in the background? But yeah max brightness does use quite a bit. See what happens if you use powersaving mode.
  8. Gebirgskuchen
    Powersaving-Mode seems to help a bit, because there are less heat spikes ramping up the fans. On the other side, the performance is much worse/slower now.
    I screenshotted everything running in the backround.
  9. Gebirgskuchen
    The rest.
  10. Joikansai
    Try lowering resolution to 1080p, pushing more pixels may also causing higher cpu temperatures than FHD.
