Razer Blade 14 (7700HQ/1060) beatdown log
Discussion in 'Razer' started by Mobius 1, Apr 26, 2017.
  1. Nuke33
    Nuke33 Notebook Consultant
    Good to hear it worked out for you ;)
    You can further reduce noise by limiting the frameoutput of your GPU to ~60hz and still use high settings.
    Use Riva Tuner Statistics Server and set a fine grained limit to your actual monitor refresh rate. Razer Blade 2017 TFT has exactly 60.020hz.
    You can use my value below if you like in RTSSes Global profile. It has very low input latency due to the gpu not rendering a lot of discarded frames. You can even use Vsync with relatively low input lag that way.
    Vistar Shook and Vasudev like this.
  2. votehart
    votehart Notebook Enthusiast
    Hi, did you ever give this a try? Curious to review all options before repasting. Seems a shim between the pipes and GPU could take some of the risk out of using liquid metal and see the best results. Thanks.
  3. B0B
    B0B Notebook Deity
    This laptop has been out for awhile. What's everyone's thoughts on it now? BB has it for sale for $1599. Looks slick and could be fun :) https://www.bestbuy.com/site/razer-...lid-state-drive-black/5753110.p?skuId=5753110
    I need a permanent machine for work and some occasional Overwatch. Something built well (I love our Apple for its build quality) and not too large. 14" seems about perfect for me.
    If I should look elsewhere just say so. My heart isn't set on anything.
  4. sk3tch
    sk3tch Notebook Deity
    It's a great bet. The only concern I would have if I were you would be that NVIDIA's new mGPUs will come out in Summer-ish (not a fact, but seems likely).
    I also owned an MSI GS43VR Phantom Pro and liked that a lot. IMO, both that and the Razer Blade 14 are the best size/performance laptops. I sold the MSI too early...my travel for worked picked up again so I decided to pickup the Razer for a change. It has been great. I own a v5 with the 6700HQ and GTX 1060. I had a 7700HQ in my MSI and I notice no difference.
    Go used if you can to tide you over, get a good price - then sell and buy a laptop with the new NVIDIA mGPU in a couple months, that's what I am doing.
    B0B likes this.
  5. don_svetlio
    I would highly advise against it - the thermals, noise, durability and support are horrible. Razer support is next to useless and the quality control is extremely poor - we've had people RMA Blades 4 times before finally getting a working one and each RMA would take 1-3 months. Not to mention that most of these machines have pretty glaring design flaws as outlined on @pbhenry3 's channel.
    https://www.youtube.com/results?search_query=pbhenry3
    B0B likes this.
  6. B0B
    B0B Notebook Deity
    Thanks for your input and advice :) I’d love to go used but I really only prefer to buy my stuff here for the most part. And there’s nothing available in the marketplace at the moment. I’m looking for something likely within the next seven days from now.
  7. don_svetlio
    Check pricing on different laptops - take it as a fair warning.
    Vistar Shook and B0B like this.
  8. Vistar Shook
    Vistar Shook Notebook Deity
    If you do opt for the RB go for the extended waranty from BB or Microsoft, just in case.
    Enviado de meu Pixel 2 usando Tapatalk
    don_svetlio likes this.
  9. B0B
    B0B Notebook Deity
    Thanks for your help guys. I’m definitely gonna pass on this one. I love the aesthetics of it immensely and the parts inside suit be great but it must be very reliable.
    Vistar Shook likes this.
  10. rinneh
    rinneh Notebook Prophet
    I saw a video past afternoon where a technician/repair specialist showed a motherboard where wired where soldered on presumably because the original design had flaws. So instead of making a new board desig. And ship those to customers. They patched faulty boards instead with soldered on wires. Thats how they ship it to customers out of the box. They should be called out. They do not deserve our money.
    Nuke33, pbhenry3 and Papusan like this.
  11. Nuke33
    No unfortunately my Blade 2017 has a problem with booting. I cant boot into windows or any graphical UI any more. DOS and other non graphical commandlines work fine. Nvflash does not detect any nvidia cards, so my guess is that the VBios chip underneath the heatsink is dead from all the heat.
    Maybe @pbhenry3 can give me a clue on what this could be besides VBIOS.
    So I need to fix this first before attempting to mod anything.
