Razer Blade 14 5900HX
Discussion in 'Razer' started by Joikansai, Jun 14, 2021.
  1. Terreos
    Terreos Royal Guard
    That would be an interesting test to see honestly. I didn't even think of that. Hmm. . .
  2. Joikansai
    Joikansai Notebook Deity
    I see, however I’ve intel xe 96EU (which’s being used on alder lake CPUs) on book 13 and far cry 6. I’ll check later how it performs compared apu on 6000 series. Hopefully it doesn’t have compatibility issues which’s usual on intel drivers compared to AMD. Intel Xe 96EU was more powerful than apu 5000 series and since 6000 use rdna 2 apu (also being used on upcoming steam deck), poeple saying it’s more powerful than intel xe and 5000 series apu that being used on handheld pc like Aya pro and gpd win 3.
  3. SunJ
    SunJ Newbie
    Hey, sorry that i quoted this Post, but do you have found a vbios for Blade 14 3070 with more wattage and working DP USB C ? I tested the Blade 17 Pro 130 one, works with Like 110 Watt, but No DP Out.. thank you !
  4. Joikansai
    Both didn’t work? I’m using it now literally, last time using external monitor was on right side usb C one using DP adapter was working fine. Let me look now. Btw I think I had similar problem before, try update or reinstall the Nvidia driver maybe. And yes I think I never see it hitting 120 watt on OSD, probably there’s some bios limitation that we can’t figure it out yet, like for example couldn’t get other brands 130 watt working properly (apps shut down or graphic glitch).
    Edit: Left side usb C doesn’t work as DP, only as usb C data transfer but on the right side both usb C and hdmi ports are working fine. So maybe for those who need left side DP this bios isn’t great.
  5. SunJ
    SunJ Newbie
    Thanks for your reply. I Just tested the left one. Will try the right one now ;)
  6. Joikansai
    Yes it maxed like 111 watt On 100 gpu usage, but better than default one, and can score 10k average on default synapse profile for 3070 mobile on this form factor is great (This year first time this pro bios TS run default costum high synapse external monitor, with gs66 vbios you can get more but hotter temperature and stupid cpu power draw read on OSD as trade off so this is sweet spot imo)
    https://www.3dmark.com/spy/25795035
    GS66 vbios timespy (less 200 points because of new 2tb ssd I think, before was 11+K overall on original SSD)
    https://www.3dmark.com/spy/25430394
  7. SunJ
    SunJ Newbie
    Nice ! Does the dp also works in this vbios ?
  8. Joikansai
    Yes but if it’s both not sure. That 11K was on external monitor since I tried to get best score once to surpass 11085 high end gaming PC score mark but didn’t succeed, was like 50 or 60 points less I think.
  9. Jesdga95
    Jesdga95 Notebook Enthusiast
    Hey all,
    Just got a Blade 14 w/ 3070 and I haven’t been able to get it charged above 73%. Is this a feature like the one some other laptops have where you can limit battery charge to a certain threshold? I’m also getting really high CPU temps using literally any mode configurable on Synapse, 90-100 Celsius while gaming which seems pretty wild. For now I just set a temp limit on Ryzen controller but I’m wondering if I should repaste
  10. Joikansai
    Wait few days let the unit optimising itself through windows update etc. I think I never heard there’s charging limitation on blade laptops usually stay on higher 90ish percentage. Try changing performance profile, quite weird though sometimes I had also high temperature even on balance mode switch it on costume boost high lower the temperature lol, probably software bugs where the fans isn’t working correctly as it should. Yes safest way using ryzen controller but recently I don’t use it anymore. If you’re used to repasting laptops I think it’s better than most oem factory repasting job, but I’d check idle temperature first if it’s fine on 40 to 50ish most probably not thermal paste issue.
