Razer Blade 14" (1060 GPU/late 2016) Owner's Lounge
Discussion in 'Razer' started by reloader-1, Oct 12, 2016.
  1. JustGary
    JustGary Newbie
    Hey Guys,
    Just got an issue with my laptop.
    Battery started swelling and I had to remove it.
    But I think that the swelling caused some screws to strip the screwhole and I got 5 different screw holes that won't get screwed in (tried several screws and they just keep on spinning)
    I will order a replacement battery but do you guys know how I could fix the screw holes? cause my panel is only scewed on the top right side and all the screws on the bottom left sides are unscrewable.
  2. Terreos
    Terreos Notebook Deity
    If the threads are stripped there may not be alot you can do. You could put a but of lock tight on the screws and kind of "GLUE" then in place. I'd be careful going this route as it might be hard to get them back out if needed.
