Razer Blade 14" (1060 GPU/late 2016) Owner's Lounge
Discussion in 'Razer' started by reloader-1, Oct 12, 2016.
  1. Vistar Shook
    Vistar Shook Notebook Consultant
    How hard is it to unlock the Bios? Any risk of bricking the machine?
  2. Rideass
    Rideass Notebook Geek
    It's super easy, if you know what you are doing.
    Actually found this guy now on the insider forum who has it explained pretty well and links to the tools you need.
    https://insider.razerzone.com/index.php?threads/razer-blade-2016-bios-mod.14368/
    By the way, there is no need to go through all those options and unlock them one by one as that guy suggests. Just change one single option to get them listed. Very minor change. See attachment.
    Regarding the bricking, if you have no clue how to reset the BIOS to default by removing the RTC/CMOS battery - well I would suggest stay away. The flash itself it pretty damn harmless. Personally I have never failed an update in 20 years.
    Risk/reward. Take a chance, win or lose.
    Vistar Shook likes this.
  3. jlp0209
    jlp0209 Notebook Consultant
    Will this work with the 2017 Blade as well? I'd love to be able to undervolt the cpu in the bios rather than XTU. All you have to do is change that one line to "show all items" to "user" ?
  4. Rideass
    Pretty sure yes, would not imagine Razer changed anything much except the CPU package and the RAM chips. That said, I do not own a 2017 model so I have no way of being sure.
    On another note, does anyone have a modded vBIOS for the GTX 1060? Would love to get control over GPU voltage, max TDP etc.
  5. xXHeadyXx
    xXHeadyXx Newbie
    congrats on your success :p hope we maybe see some more bios mods tweaks fixes :p sounds interesting
    what i think would be interesting is what happens when you fake your device to be the 2017 version ( in a way that synapse lets you controll the fans with the auto high and silent option :p who knows if it works :p )
  6. Vistar Shook
    I think the fan profile on the skylake version after the update might be better than the kabylake one. True that even after the update, the fans are still running on idle while the kabylake is completely off....but on the skylake the fans only ramp up when the cpu reaches 70 degrees while on kabylake that happens at a lower temperature so many report the annoying pulsating fan, where it comes on then off then on again depending on how the machine is being used.
    Sent from my SM-G930F using Tapatalk
  7. Vistar Shook
    Just out of curiosity....I will be repasting my machine in a month or so....just to see if there is any temperature difference. I am opting for kryonaut for now since I don't have enough experience to try the liquid metal yet.
  8. Rideass
    I would not attempt to flash the 2017 BIOS, might be a lot of minor differences in the ACPI tables etc that could cause total disaster and be impossible to recover from. But yes, I might be willing to try this later this year as its very easy to restore any changes. Not sure how synapse detects the machine if it uses the serial no, or part asset tags. Should be easy enough to spoof, do not believe Synapse is smart enough to poll CPU config etc.
  9. Rideass
    I would be willing to try if someone gave me a DMI dump and a dump of their BIOS from a 2017 machine.
