Ranger 17 gpu fan does not spin, ever. Any ideas?
Discussion in 'Alienware 17 and M17x' started by VoodooBane, Nov 28, 2018.
  1. VoodooBane
    VoodooBane Notebook Geek
    My fan is not spinning at all. I have an msi GTX 1070. The drivers work AID64, HWINFO64 all report the gpu temps the nvidia drivers install with no problem. The fan just does not spin at all. I replaced the gpu fan, the daughter board. The heatsink is clean. I even too a spare cpu fan and that ACTUALLY worked. So what is the deal?
    I replaced the battery not to long ago could the have caused it? Also my bios is a14+ unlocked.
    Has anyone had this issue? Or have any clue to what maybe causing the this issue?
    My last resort is to do board level repair. Ehich i can do but does this sound like software? Any tricks u guys have up your sleeves?
    Sent from my SAMSUNG-SM-G928A using Tapatalk
  2. TheReciever
    TheReciever D! For Dragon!
    You could pull the PWM wire, if it still wont spin then you then will know its probably a hardware issue.
  3. Grant B Gibson
    Grant B Gibson Notebook Deity
    I thought it didn't have Gpu fan control for the 1070? Might be wring, but do fan control softwares work? Like HWinfo?
  4. VoodooBane
    Yes there is no control for the 1070. I issue happened so random. Hwinfo to see the temps is all i meant. But how does the cpu fan a m14x r2 fan work but a 11.4cfm randomly stop working? I have try 3 different fans. And 2 daughter boards
  5. Grant B Gibson
    My thoughts are that there isn't Fan Control present for the MSI 1070, use HWinfo to try and spin the fans
  6. VoodooBane
    I tried that and nothing. No spin of anything
  7. TheReciever
    Remove PWM pin.
  8. VoodooBane
    Ill try that when i get home in 3 hours and report back.
    Also any chance know the color? Yellow or blue?
  9. TheReciever
    I think @Striker1234 knows
    I somehow cut both without knowing it so I cant say for certain lol
  10. Striker1234
    Striker1234 Notebook Consultant
    If i remember correctly, cut the ones in the middle and leave the ones in the edges!
