Raising The Power Limit On My MSI GTX 1060 MXM Module
Discussion in 'Alienware 17 and M17x' started by Clamibot, Oct 3, 2017.
  1. Clamibot
    Clamibot Notebook Deity
    Hey everyone, so I used Coolane's Mobile Pascal TDP Tweaker to raise the power limit of my Alien's 1060 from 78 watts to 120 watts so I can get the same framerate in all games as my similar spec desktop does.
    The problem is that when I try flashing the modded vbios using NVFlash, it gives me an error message: Screenshot (36).png
    I've used NVFlash before to unlock my GT755m's on my Lenovo Y510P before and never got this message. Am I doing something wrong?
  2. Mobius 1
    You cannot use NVflash, need a physical programmer.
    If you've at least read coolane's thread you should know :v
  3. Clamibot
    But why not? I thought he said there needed to be a version of NVFlash that supported flashing pascal vbioses before we could use NVFlash to flash them. The newest version of NVFlash supports this as far as I understand.
  4. Solo wing
    Solo wing Notebook Consultant
    I believe you could only use Nvflash to flash the original/ signed/ non-modified vbios.
  5. Clamibot
    Ah ok, thank you for the clarificaton.
  6. Clamibot
    Update: It seems I can't use nvflash to backup my vbios either. Any command results in this error:
    ERROR: Unable to start service (0x0000001F)
    Detailed :A device attached to the system is not functioning.
