Radeon HD 7690M? Info please?
Discussion in 'Gaming (Software and Graphics Cards)' started by ddog510, Jan 13, 2012.
  1. Ellatan
    Ellatan Old Timer
    Ah, I see, you have very good attention to detail and that is a fair point. I'd also second a request to have Vantage scores redone in 1280x1024 with basic performance options for a fair comparison.
    Could you guys OC to the same clocks and compare Vantage performance of XT and non XT just to reinforce Kevin's point? I'm only referring to GPU score in Vantage obviously.
  2. etiko
    etiko Notebook Consultant
    Not really i have been done at 1366xsomething. but ok i will do it, i must be connect to an external monitor ;)
  3. etiko
    you want fair comparision? here it is, one note only, this scores has been maded while downloading BF3 from origin, i think its affect CPU score but doesnt matter for me.
    overclock 900-1000:
    [​IMG][/div]
    Stock:
    [​IMG][/div]
  4. Ellatan
    Ellatan Old Timer
    Awesome, thanks Etiko. Could you do the same for Vantage please?
    yknyong1, could Envy 15 have a stable overclock at 900/1000 for a comparison?
  5. etiko
    yes i will do but i will wait The origin download of BF3, i purchased today a key from a web site its very cheap, and it work
  6. etiko
  7. etiko
  8. yknyong1
    yknyong1 Radiance with Radeon
    Max 800/1000. Limited by no voltage adjustment possible.
    Anyway, the scores are very similar at 725/800, which indicate they are the same chip.
    7690M non-XT -1.00V
    7690M XT -1.05V as said by HP owners
  9. Ellatan
    Ellatan Old Timer
    9500 in your case and 10800 in his case on stock in 3dMark06. That's almost 14% difference, which seems strange to me.
    Could you also run Vantage in 725/800 and post it here?
    By the way, one of the forum members have just recieved Y470P with 7690M and is in the process of testing it.
    [​IMG] [​IMG]
    That's his GPU-Z that shows DDR3 memory, 32 bit and 4 ROP. Seems really strange to me. Then later GPU-Z showed 128 bit and 16 ROP. Will repost here as soon as he gets some scores.
  10. fallensoulja
    fallensoulja Notebook Enthusiast
    quick questio guys which will give me the most fps for gaming, and i mean games like bf3,cod mw3 saints row 3 etc
    and does the 2gb of ram on the 7690XT make that much of the diffrence?
    • Genuine Windows 7 Home Premium 64-bit
    • 2nd generation Intel(R) Core(TM) i7-2670QM (2.2 GHz, 6MB L3 Cache) with Turbo Boost up to 3.1 GHz
    • 2GB AMD Radeon(TM) HD 7690M GDDR5 Discrete Graphics(TM) [HDMI, VGA]
    • FREE UPGRADE to 8GB DDR3 System Memory (2 Dimm)
    • 750GB 5400 rpm Hard Drive with HP ProtectSmart Hard Drive Protection
    • 6 Cell Lithium Ion Battery
    • 15.6" High Definition HP LED Brightview (1366x768)
    • FREE UPGRADE to Blu-ray player & SuperMulti DVD burner
    • HP TrueVision HD Webcam with Integrated Digital Microphone and HP SimplePass Fingerprint Reader
    • 802.11b/g/n WLAN
    • Standard Keyboard with numeric keypad
    total $836.99
    or
    AMD Quad-Core A8-3550MX Accelerated Processor (2.7GHz/2.0GHz, 4MB L2 Cache) (Newest High End Amd A-series CPU )
    1GB AMD Radeon(TM) HD 7690M GDDR5 Discrete Graphics(TM) [HDMI, VGA]
    FREE UPGRADE to 6GB DDR3 System Memory (2 Dimm)
    FREE UPGRADE to 640GB 5400 rpm Hard Drive with HP ProtectSmart Hard Drive Protection
    6 Cell Lithium Ion Battery (standard)
    15.6" High Def LED HP Brightview (1366x768)
    SuperMulti 8X DVD+/-R/RW with Double Layer Support
    802.11b/g/n WLAN
    total: $716.99
