R61 questions
Discussion in 'Lenovo' started by gmaster, Mar 19, 2008.
  1. gmaster
    gmaster Notebook Consultant
    i was about to order today finally after few days of research and right before i order i wanted to know if it comes with a SD card reader.. on the T61 i see the option but on the R61 i dont see any option.. im lookin at the 15.4" widescreen one.. am i missing something??? I need to be able to read SD cards..
    Thanks in advance..
    Dave
  2. drjohn
    drjohn Notebook Consultant
    I have a 14.1" R61, which I got about a month ago and I spec'ed it with a media card reader, along with the built-in PC card. I assume this is also available with the 15.4" versions (which use a different chassis), so you'll want to check to be sure. If so, the media card reader is an SD card reader so I think it's got what you want.
  3. stebesplace
    stebesplace Notebook Enthusiast
    Yes, it comes with a Ricoh R61 4 in 1 reader that handles SD cards just fine. I used mine a few minutes ago actually. I have the 15.4" model, btw.
  4. gmaster
    drjohn.. thanks for the reply.. im going back and forth trying to decide.. i have the R61 with the following specs in my cart.. but i dont see anywhere to add a media card reader..
    ThinkPad R61 - 1 Year Depot Warranty
    Intel® Core™ 2 Duo processor T8100 (2.1GHz 800MHz 3MBL2)
    Genuine Windows Vista Home Basic
    15.4" WXGA,BT
    Intel GMA X3100, GM965, 1394, S-Video, PC Card/PCIe
    1 GB PC2-5300 DDR2 SDRAM 667MHz SODIMM Memory (1 DIMM)
    UltraNav (TrackPoint and TouchPad)
    80 GB Hard Disk Drive, 5400rpm
    DVD Recordable 8x Max Ultrabay Enhanced
    ThinkPad 11a/b/g Wi-Fi wireless LAN Mini-PCIe US/EMEA/LA/ANZ
    Integrated Bluetooth PAN
    6 cell Li-Ion Battery ( 2.4 Ah )
    8932: 1Year Express Warranty
    when i went and added a 14" r61.. it gives me the option to add pc card and media reader.. i dont understand it.. when i configure a 15.4" r61 with the same specs.. i dont even get the choice on system expansion slots... hmm
  5. gmaster
    when you spec'd yours out did it give you the choice or did it automatically come with the ricoh 4 in 1 reader? im so ready to order.. :) this is just confusing me.. is the reader on the left side or on the front.? any pics?
    now this is weird.. if i check the details.. the 14" r61 i added the media reader it doesnt even show it in details.. it looks exactly like the 15.4" one w/o it.. hmm
  6. stebesplace
    Hmm, its not listed anymore on the 15.4" R61 (Note, not the i or e). So I wonder if its included? It used to be in my list when i ordered, but the old santa rosa proc's were listed before too, and those are no longer, so I don't know. I checked the R61, R61e, and i and its not listed on any. So I guess I am not 100% sure. I would call them on this one...
  7. gmaster
    stebesplace.. what version of the screen did you get? i checked the resolutions.. i think 15.4" WXGA will be fine for what i want to use it for.. im not doing any spread sheets or anything.. just mainly internet/divx movies/quickbooks..
  8. stebesplace
    mmm, I got the larger resolution because I do web design and wanted the better realestate. For me, if I was getting the 15" I wanted good resolution, if the 14", I would prefer the lower resolution. I guess if you don't need a lot of pixel estate, then go with the WXGA+.
  9. Saneless
    Saneless Notebook Evangelist
    Media card readers are 10 bucks.. I really wouldn't worry about it either way.
  10. u2giants
    u2giants Newbie
    besides SD, what else does it read?
