R1 usb question
Discussion in 'Alienware M11x' started by Consi Pit, Oct 6, 2011.
  1. Consi Pit
    Consi Pit Notebook Evangelist
    Hello
    One of my usb ports, ( on the left side) is always turned on. Even if the computer is off . Is it ok ?
  2. c4sc4
    c4sc4 Notebook Consultant
    That usb port has some kind of power share option that you can turn on/off in the bios. If it is on, it powers that usb port so you can charge things with the computer off. I forget what the setting is called but if you look through the bios menus you should be able to find the setting to turn it off.
  3. Consi Pit
    Many thanks for your answer .
